Arno Nel wrote:
What size baits are you okes puting out there with the kites ?
Anything you can slide , I'll drag out . Difference being : time - Quicker , and Definite. Where it Drops , it's on athrow , so if something takes it your chances of it going through the Leader are slim ..
And obviously then , ahh, would be distance . Try throwing and then Sliding out 350 m ..........
If wind Speed is up , and i Want to put out a kilo bait . off We go . Less wind , half kilo bait . until iut becomes Impractical to use kite , then everyone whips out their straightest Long Faces , plants their Feet , and ....dare i Say it .....- Casts .
Once you Get spoilt by having your bait dropped , casting becomes like something compared to Getting out of Bed .on a winter's morning . Not Lekka ! .
It's a Little More Finnicky thought than you'd imagine , and as i said Previous - get a Tyrnos On special , as you'll need a Marlin reel that can handle 15+ Kilo's of Pressure on the wind-up , continuously . Make No Mistake , it has Nothing to do with winding on the braid so bad the spool pops .It's got More to do with the amount of pure STRAIN you Place on the gears , when you try with your Best attempt , to Reel in said kite , from 35 000ft . Once the bait Releases , it shoots up into the strong gusty area , and Pulls Like HELL .
If the wind is just keeping it up there , it still presents a Mission for Even something like a Dc, Buck ....6.4:1 don't work here bru . Here you Need brute force . Bring that sucker DOWN ....... Problem is once you get the hang of it , you start wanting to Let your Bait Out further , and further , and further , and ..- you Get the picture . Obviously sanity must Prevail , and I'd say anything between 300- 650M(crikey) is sufficient , but seeing your Moerse Ass go out beyond the breakers , over the Shorebreak , through the surf , all on top of the Water until you tighten up and it gains some altittude until it drops off .
eish. The chokka baits Make like a slow-motion Drop , Like when they slow down a stallone punch ! i Use a 6oz sinker , or 7 Oz. Nothing More , really .
But On the whole < One's bait Is determined in size , to wind , and the type of kite . The one i use , this Delta-winged treasure of torture , will probably in a stronger gust , lift around 800Gr . a full size Mack mack . up , up , and away .....
The wind simply Needs to be Strong enough to Keep the kite Moving backwards , and then you can prettyMuch Pull anything out Past Through the Backline . a Small Live shark , for instance, like a hammer , can be goaded out into the deep blue on a pulley rig , until father time comes Knocking to shorten it's life .
