Sakkie definately a bigger hook and never strike a steenbras, if its pulled you down in your rod holder its on,the drag setting should not be to loose though, then just reel and play the fish.
I make a loop through the worms head when I bait up, the worm will never slide down. If your bait is being stripped so quickly its more than likely crabs chowing the worm, some guys will use floatation, not sure if it really makes a differance.
The Hermanus plaat has been giving good steenbras and some really big galjoen the last couple of weeks, biggest i heard of was 11 kg steenbras and 4 kg galjoen ??
Stywe lyne
Stywe lyne
