Galjoen 2022
stinkmossel
Lotsa smaller Gallies around at the moment though- looking forward to the bigger falsebay gallies!!
Rademeyer fishing standing on 84 gallies for the season so far, biggest fish only 45cm- with some busses being lost and dropped. still amazing fun on any tackle!!!
Fly-aholic
DJP wrote:
Thanks for the feedback and congrats on opening your gallie account Fly-aholic!
I did a few short dusk sessions last week, not even a klipvis bite. I guess it's part of trying to figure out new waters.
As far as I know it's CoCT cleaning up the kelp, rebait etc.
Although it's nice to have a "clean" beach I think it's total bs. they messing up the ecology of the area even more. A lot of intertidal species depend on rotting/decaying matter to feed on, with them removing the material they are reducing the nutrients which probably has numerous knock on effects.
Hi DJP,
Where were you trying and which is a new area for you?
Yes, the ecological effect is true. However, with the amount of line, float and hooks intertwined in the bamboo I feel the risk and ecological impact may be more by not removing the aforementioned. The 2 evils, which 1 is better?
Fly-aholic
Hi DJP,
Sorry DJP, I did not see the red bait comment included in the thread. I doubt if CoCT cleans up the red bait pods. I stand to be corrected, because if that is the case then it should not happen.
Fly-aholic
Quick question regarding braid. I find that 30 pound is light for Gallie fishing, especially considering that we fish the bricks for them. What braid rating do you guys fish for Gallies?
I am tempted to put the 50 pound on my Spheros for Gallies, and very short clear leader of 1 meter max. At least if/when I break off I do not leave braided leader of 8 meters behind. Ja, ek hengel grinder.
DJP
I use 80lb on my 15/30 multiplier and 40-70lb on my grinders. I have lighter setups with 20lb braid but the areas / conditions you can fish with it is very limited.
I love my 15/30 for gallie fishing, and that 80lb braid I seldom loose even a foot of braid. I use a 0.75mm-0.80mm leader.
I now have 40lb Boss Braid Hi-lite on my Big bos 8000 grinder, enjoying the braid and cast well.
DJP
Hi DJP,
Around Hermanus, we moved here last year. I know Betties, Hangklip and those areas all the way around to False Bay, but haven't fished this part much... in fact I'm having more luck on the plaat than Hermanus it self.
Fly-aholic
Hi DJP, thank you. I agree as casting for Gallies between the rocks, and leaving 9m of leader in the water is just not good. The 40 pound normally breaks at the leader (0.60) and I leave the braided leader behind. I have also resorted to NOT using braided leaders anymore as they normally stay behind after breaking off. So now I am thinking 50 pound for rock fishing and short 1m leader. the chance to get your hook trace and short leader back is also higher as the sinker line is very light (0.50). Ok, I am convinced.
Interestingly, I have read somewhere that 4x braid is more abrasion resistant due to the lesser and thicker strands. I have not tested this, but makes sense.
Marthin
80lb and 50lb braid.
For gallies and general areas up to where cracker can be found i use the 50lb on the one 15/30, .70 leader, .60 hooktrace and .40 sinker trace. I don't fish nearly as often as i wish to, but i have fished some sessions let's say 6 days total where i've never replaced the leader.
Further east, it's the 80lb stuff, .70 or .80 of that harder leader line sportsmans sells, i see it's at FS now as well.
bump up the hookline to .70 maxima, and i have fished for both cracker and gallies on the setup from tuesday to sunday, landing a few fish in the time without having to replace the leader once. It is also better for the fish, should you break off, as it ends up with only 20cm of trace in stead of the leader as well.
Fly-aholic
Hi Marthin, how long is your leader on the 50 pound setup?
Marthin
I fish on a 14ft rod, so its 2 turns on the reel, length of rod plus about 80cm
I also have 50lb on the grinder, off 12ft rod, and for that it's only from rod tip to swivel, roughly only 80cm, its the outfit i got that big gallie on, and it went over and across every reef it could find on the way in, thought it was a small cracker at first. Rod tip high, drag loose and hope whatever it hits hits on the 80cm of leader, worked out ok. If it was deeper water and i was level with the water it can be an issue i guess because of the angle, but i was never going to bully that fish on the tackle.
stinkmossel
i remember when i was using multipliers- it was either 50lb or up to 80lb-(the old fireline). now its around the 40 to 50lb range.
leader around 1.2 -1.5 m.
have to agree with Marthin,especially when fishing in the Southern cAPE- GO FULL LEADER!
Fly-aholic
Thank you Rean and Marthin,
Settled then- tonight I will spool the 50 pound braid on the Spheros with 1m-1.2m leader((goodp_
BigBen
For me on the 12ft Loomis and Tor16, its 50pd braid with a 2mtr leader in the brix..
Landed 15 good but maer gallies in 3 session and kept 1 42 cm for this weekend braai...
Fly-aholic
Hi BigBen 42cm Gallie is fantastic. Was it here in Cape Town? I have been catching small Gallies only, 32-34cm.
Yip, looking at all the line washing out with the bamboo, hell I cannot see me fishing 30-40 pound braid and 8m braided leader anymore for Gallies and close fishing. Will put the 30-40 pound spool back when going for the cobbies on the far out reefs.
Fly-aholic
BigBen wrote:
Yep Hunting all my old spots....60% caught at the strandfontein pool area..
Read water and you on dad
BigBen - how is the 'getting stuck' situation at the pool area? I realise that I'll brak off, but some places are just to foul (line etc).
BigBen
I loose verey little...When sinker roll into/onto rocks..jerk upwards and reel...
When you "drag" reel the sinker its bye bye
Fly-aholic
BigBen, very interesting comment. Let me clarify my understanding and please correct me if I am wrong:
1. After you have made your cast, you DO NOT let the sinker drift until you are on the rocks
2. With each cast you attempt to cast onto rocky areas.
