Step 43.
Once the clay was removed it was time to dislodge the box. A paint scraper is the tool for this. Gently push it in between the new rubber and the box and then run it all along each side. Push the mould down at one end and she should slide out with a little help. Once you have the mold out you can pull all the mold keys out and you'll end up with your first half. Try and keep the thing on a level surface so that you don't dislodge the part being molded.
:headb
