Step 38.
The most important section. Mixing the RTV (Silicone) and hardener. If you don't have an electronic scale run a piece of masking tape up each side of the two containers. Mark the top of where the liquid sits in both instances. Divide the distance into four segments ie 100mm total, mark at 25, 50 and 75mm. The same on both containers. Now you have a fairly accurate way of measuring equal amounts of the two materials. The system in use here has a mix ratio of 10:1. 1Kg Rubber to 100gr of hardener, Get the Silicone into a container and add the hardener. Use a paint scraper, spatula or piece of wood to fully mix the solution. The colour of this mix is the most "GAY" colour I have seen yet but we have to live with it. Mixing is tough but you have to do it right. I like 15 minutes including scraping the sides of the container so that if you let the material run off the spatula it is of a UNIFORM colour. No cream and white marble effect. Get this right and don't panic. You have TIME!!.
