Rods for casting long range
HENIEKIE
Thanks Enigma
So over all its not a bad rod? When i just got them i screwed 2 golf balls together
and stood at the base line of a rugby field and managed to cast to the other end
at least 80% of every cast.
Welkom by Sealine. Jy het dit sommer met die intrap slag reg gekry
Maar pasop om threads te Hi-jack. chat op relevante thread of begin 'n thread in die relevante afdeling en ons chat almal saam
GP_Angler
Wow, Enigma your feedback on rods is awesome, sincere thanks.::S'
I have recently purchased the Rovex Nexium 7000, and truly enjoying the reel. I am in the market for a decent rod, and have this major mental confusion on carbon fibre and graphite rods.:fbash'
I read on a few forums on the superior casting power with graphite rods. And the Raging Bull seems to be the ultimate of casting rods. I stopped at Western Accessories today to find out that the Raging Bull is a carbon fibre rod and NOT a graphite rod. Some clarity and education on this would be most appreciated.
I do like the Rovex Nexium 13ft rods, but have not made the purchase as yet. Enigma your comments or anyone else, would be most appreciated as I need to purchase a decent casting rod soon. (Enigma your comments on reel, line, lead, anglers skill, is spot on and duly noted)
GP_Angler
:SSS Some information to share from reading....found it helpful to a novice like myself....
What's the difference between fiberglass, graphite and carbon fiber fishing rods?
All three materials consist of a matrix of fibers rolled into a tube; yet each material offers very different properties. Fiberglass is flexible and strong making it good for trolling rods or fighting heavy fish. Graphite is sensitive but brittle; a good choice for targeting light biters or deep-water bottom-dwellers. Carbon fiber offers better sensitivity and performance than graphite while being tougher and heavier. Carbon fiber and graphite also have a faster response time than fiberglass making them good choices for long casts.
Carbon fibre and Graphite rods are the same thing. it is a terminology issue where rods are constructed from Carbon Fibres laid in pre-pregnated (with epoxy) sheets.
these sheets are rolled onto mandrels in assorted patterns and layers which include carbons of different strand densities and in some cases a layer of glass pre-preg to increase the hoop strength of the tube.
Make no mistake with Glass rods there are also differing modulus and density's providing S-Glass, E-Glass etc, etc
There are no rods made purely of Graphite as it is not a material with the charateristics that will make a flexible tube.
So what is referred to as a Graphite rod by anglers is in actual fact a Carbon rod.
TotalNoob
Question, why do I cast my 8ft rod loaded with 1 ounce furthur than my 12ft rod loaded with 4 ounce weight?
I cant cast my 12ft rod properly, the smaller rod is a breeze to cast with and it loads/bends nicely before letting the weight fly.
I have a side cast action that I use on both rods so similar actions.
Does anyone here look at the trace just as you are about to let it go, so you can let go of the line in time? I do this with my 8f and 12ft but its not working so lekka with the 12ft :( - i need to nail my casting with that 12ft.
Any tips appreciated!
life good
GET THE SENSATION GREEN MUMBA IT THE BEST YOU CAN GET THROWS WELL OVER 210 M COST r1150 at alpha pro in brackenfell thats a good rod i would love to get it but expensive im geting myself the juke bomb sensation similar to what you have now
Check again the Green Mamba was put in the market as a limited range of imported Blue Marlin rods and is not on the Sensation catalogue. the Green mamba of Blue Marlin is an imported T53 that they tested in the market but it didn't get the reception expected and doesn't do nearly what the G2 does (made in RSA by Blue Marlin)
Sensations top rods at the moment at the DC's
Schalk's custom builds are Blue Marlin T53 either the 365/2+1 "Terminator III" or the G2
The G2 is the blank I recommend the most in this thread
As a confirmation here. I had 8 clients come in to test rods for their custom Builds. Tested DC, Rocket, Raging Bull and G2, 7 of the 8 bought the G2's and the 8th is saving up for his G2's and has 2 x customised Raging bulls for sale if someone is interested.
LeonK
howzit craig
are the RBS's 12 or 13's and what was customized?
price?
Beeslek
Hi everyone.
I only joined Sealine recently,I find this discussion really interesting since I'm also in the market for long distance casting rods.So my question is for Enigma.Should I buy the Sensation DC's off the shelf,or should I buy a proper blank and have it custom built?Price is not an option,I'll spend whatever is necessary to get it right first time.I see that the current S.A distance casting record is held by a rod built on a Purglas 400/7 blank,so I sort of have my mind set on Purglas.The second part of the question is that I would also like to use them for specimen carping,sometimes at long range.Would such a stiff rod be suited to landing a big carp from range,or should I have different rods for that application?I'm a fairly large guy,1,9m and 115 kg,so I think I'd be able to add a fair bit of power to a cast.I see that in an earlier post you mention a Purglas rod with a 3lb tip and a 5lb backbone,that would cast anything from an M1 to 7 ounce weight.That particular option sounds REALLY good.Thanks,looking forward to your reply.
Welcome...............:welcomesea:
Nothing wrong with the DC as is off the shelf, I personally am just not a huge fan of the absolute stiffness of the tip and the average angler loses a lot of fish with it but that said you should have more than 1 set of rods and these rods "as Titled in the Thread" are for long range fishing. Personally i still prefer the Blue Marlin G2 which does the same in terms of casting but has a bit more tip action.
Although the DC has 2 tips and the lighter tip is great for launching lighter weights and the heavy tip great for large weights both are unforgiving in playing fish but price point of R1500+/- for a top rod with 2 tips can't be beat.
G2 with single tip and same guides as DC will cost you R1850 and with either Fuji Lo Rider or Concept (both alconites) you're looking at R2200 and around R700 per tip to upgrade the DC to Fuji concept guides
That is in tournament casting whith a multiplier and the rod weighs in a 1.3kg and is not the off the shelf /7 where the G2 is 480gr and the DC with light tip about the same. The tournament casting record is with a 150gr weight, not what you going to be fishing with.
To put that record into perspective, when competing with Century and Zipplex rods it comes in at what would be considered the top tournament casters's good distances but far from Record distances in the World Stage of casting, unfortunately none of the RSA casters in the past 10 years has been seen in the top 10 of world casting for the FIPSed Tournaments although they are consistently good
The Limpopo Carp Angling Team - Specimen type fishing, all have the G2 and this is used when fishing Extreme range with hooks as small as #10 and Marius and I landed 460kg of Carp at 140-160m without dropping one but yes you need to be a little more cautious, 2 of the pegs in the team that won the 2011 World Carp champs in Italy fished with G2's because of the range they were fishing where they caught 6-12kg Carp on 4.5m long Zig Rigs at 140-160m, haven't fished DC's in specimen applications so can't comment fairly
With all respect I don't know you but Louwtjie Louwies is probably 1.7m and 75kg and he throws way further than most anglers, irrespective of size. The truth is that maybe 20% of people who own DC's get 90%+ of the capacity of the rod, timing, power and release are all CRITICAL and these rods need combination of all 3.
I often get anglers coming to me asking me the build them the MAGIC rod to cast far, only to find out they already have the rod they need and either need to work on technique or go to the Gym to get the rod they already have to do the job.
I was working on the development with Purglas on this but they never went forward with the project and didn't get the higher Grade materials needed to finalise the project, problem was we could build the rod but with the slim taper and low modulus graphite the rods (completely) come in at double or more than double the weight of the competitors and without the Higher modulus the curve becomes to parabolic requiring a slower loading with a wide swing followed by a power snap so currently not a preferred option and then you'll have to take it as a single piece rod
Beeslek
Thanks Enigma,that clears things up very nicely.Also thanks to everyone else for their contribution to this thread,it's the most informative discussion on this subject I've ever come across.I'm just a social angler,so the DC's should do the job for me.I'll get them and then learn how to optimise their casting performance.I've always fished with fairly stiff rods,so their action should fit my casting technique fairly well.Looking forward to playing with my new toys!
Waldok
Ek hoor daar is n rumour dat die nuwe reeks Sensation DC's in Augustus uitkom. Dink dit is n upgrade van die huidige DC's. Het nie veel info hieroor nie.
