Hou My Vas Koperaal...
OK, everyone bear with me here, I am going to launch into a bit of a diatribe…..
OTGMan and I have shared a PM or two tonight.
I asked him to share (as long as did not give away any of his secret formulae) his set ups.
I will keep my promise.
The KR Concept makes promises of more rod power, hook setting power etc, but what a LOT of us want is to cast further and more accurately. No?
I have read a fair number of posts on a variety of websites and indeed books such as John Holden’s Long Distance Casting†that multiplier setups inherently cast further. Indeed the world record is held with a multiplier.
But is is it JUST down to the type of reel?
If you had to compare a multiplier rod with a spinning rod what is the biggest difference?
To me it’s the number of guides.
A Shimano Crucial 7’2†spinning rod is fitted with a tip + 8 guides, and equivalent 7’2†casting rod, tip + 9.
Why?
Typically a baitcaster/multiplier reel is LOW to the rod and since the rod is inverted, the line runs close to the blank; what need to be done to avoid line dragging?
Fit more guides.
We (all?) think that guides are the principal source of friction on a rod. Not so. It’s the contact between the line and the rod.
The contact “patch†between even thickish line, say 0.45mm and a size 12 guide is insignificant in comparison to a 40mm or 50mm section of 0.45mm line rubbing against the blank. At high speed it gets worse.
Keep the line close to, but keep it OFF the blank.
I think that most if not all spinning rods would benefit from fitting at least a couple of additional guides to achieve this. (This is where the KR Concept offers a BIG positive; will come to this shortly)
I do understand that when fighting a fish the line is being pulled away from the blank so we could use less guides, but significantly when we cast and the line is flowing from the spool towards the tip; if not kept away from the blank it will be a far more significant source of friction than two or even three extra guides (re read the contact patch bit above and think of a car tyre on the road)
Now to KR:
The concept calls for a stripping guide relatively close to the reel; from there it quickly gets reduced (or choked) down to the blank at a point MUCH closer to the blank than in more old fashioned Cone of Flight or even New Guide Concept builds. This means that we need to fit 1 2 or even 3 more guides…..
I truly believe that the true advantage is the result - MORE guides, not less. More guides closer together KEEP THE LINE AWAY FROM THE BLANK.
More guides spread out over the blank extract more casting power, more power less friction?
Longer casts.
There have in the past been other high framed guides, but NOT with the same advantages of the KL-H guides.
Fuji’s own AT guides are almost as high, but to me look like stretched single foot fly rod guides. They are not stiff enough to resist bending under significant load. Good guides for thin lines at close range they are though…
Also the ant-tangling properties of K series guides (that KL-H guides share) become MORE important if the guides grow taller - there is more of an obstruction for the line to wrap around…
KR Concept simplified is a series of 3-4 guides from stripper to choke that capture the coils and then bring it down to the blank UNDER CONTROL i.e avoiding line slap and its result - friction.
From the choke (first of the smaller running guides) the line runs in one straight line to the tip i.e the smallest cone possible.
Please do not confuse KR with Micro guide layouts, there are some similarities but the differences are big.
Also the fact that most KR layouts you will come across (if you drag the internet they will come up) call for very small 4.5 or 5 running guides DOES NOT mean that this is a rule….
The 10’6 rod that Engima tested uses size 10 running guides… Whilst clearly smaller than a size 12 or 16 guide EASILY allows for a 50lb braid to 25lb braid knot to pass through.
I am planning to test 80lb to 35lb soon. I Have tested 35lb Nanofil to 40lb mono and it goes through no problem.
Thoughts anyone? I have thick skin…
