Fuji KR Concept
Tackle-holic
Never said there was anything wrong with fixed spool reels....
Just think that the rods would be better if fitted with an extra guide or two, what ever type of layout is used
kitefisher
What a whopping thread,great posts allround.From what I've read and remembered(getting old :-( ) ,just a few opinions.
OTGman ,the best proponent of casting with a ''straight'' right arm/hand must be Poidevin from France,consistently in top 10 at Worlds for a very long time.aka The king of ''leverage''
Records between Multiplier and Fixed spool can be deceiving.For the amount of European/British-Tournament casters using Fixed-spool,the records are very very close,i.e mostly less than 5% distance wise,perhaps even less.If Big D used Fixed as often as Multi,it would be interesting to see records over time.?At the moment not the same ''man-hours'' go into Fixed at Tournaments as for Multiplier.
Enigma,You and everybody here, have a vast knowledge of guides and rods which I do not have and never will have,but if I may wager my opinion on fixed spool for European style Tourney casting it would be this.The minimum leader thickness of leader is .70mm Mono ,even for 100g/3oz,and even with a small knot which can be very small because you don't need to pull a fish on it the crack-offs are incrementally more than for a Muliplier.Difference is the way line comes off spool between Multi and Fixed spool.Coils vs no coils.
The Argentinians have ''solved'' this ''knot''-problem, by ''fusing'' mono and leader together seamlessly by using acid,in fact they believe it it so strong that they even fish with it.(pretty much the same as tapered leader (which may not be used at Tournaments),but they go directly from mainline to leader ,seamlessly,pretty neat once you've seen it.
Back to the point of Fixed in Distance casting,Mono,even .25mm will empty the spool quickly and friction against the spool lip is a factor in older reels without Ultegra/Bull's-eye or Basia-type spools.
Fixed is also affected more by wind that is not right from behind the caster.Perhaps more line than what the lead needs is blown from the rod-tip,or even between the spool and first guide.More line in the air with a cross-wind will possibly mean the lead has to pull harder to achieve same distance as Multi. Multi cannot have too much line between spool and first guide as that is immediate break-off,so I suspect that too much line outside tip is not the main culprit.
There will not be one rod for many applications,one rod may be used for many applications,but will most likely not be the BEST for any of them,although still good enough for most(if that makes sense).Finding this ''holy-rod'' for each application,is a lifetime journey and part of the joy of fishing and casting.
p.s OTGman and Kopstamp,this video is an example of a fairly straightish Right arm which makes it necessary for a very strong left-arm pull.In other video's this caster maintains an even straighter right arm. Try it sometime,slightly longer drop as the first ones tend to go lowish and leftish(for right-hander),thereafter,once the exagerrated left-pull has become muscle-memory, the distance can only improve.The low and left is due to later release of spool because of overly concentrating on pulling harder/faster with the left-hand.
http://youtu.be/p9Vfv49M1pU
OTGman
I have been punching my rods for too long and haven't found any way to improve. Tried it for 6mths and starting to see improvement. The logic is nothing new, it is from brighton cast. High left hand (far from body) pull hard. I didn't notice until my instructor explained to me.
Another person to look at is John De Vreeze. Very relaxed but casting reasonably far.
We shall discuss in kitefishing section, since I already stop discussing about guide concepts already. Thanks for sharing.
Tackle-holic
Re bind of Awa-Shima Beast Shidai 8’ 10-45g
I picked up a couple of Awa Shima rods from Enigma for testing of Factory Build vs Fiji KR when I dropped off the 10’6” Sensation DC
As standard the little 8’ Beast Shidai is a very nice rod that casts well so was a little apprehensive if any improvements would be made….
I would describe rod as having a parabolic bend with VERY quick recovery, it stops dead after a good shake.
Craig demo’d dragging the rod tip down whilst I held on fully expecting the tip section to explode…. it seems Awa Shima are not pulling our legs with their "Super Tips" logo….
RESULTS (I do realise the results are from just me casting and as such are not without flaws)
Std Configuration (9 guides + tip)
23g Onde Onda Spoon average cast 53m
45g lead average cast 70m
KR Concept Configuration (11 guides + tip)
23g Onde Onda Spoon average cast 62m
45g lead average cast 83m
Just for because i tried a 56g/2oz lead: (outside of rods range)
Std rod was overloaded and only managed 74m
KR Concept 89m average.
23g spoon 11m improvement (17%) This was into a head wind yesterday afternoon
45g lead 14m improvement (20%)
56g lead 15m improvement (20%)
Brandon do you have some Pics of the Before and after?
How did the KR concept rod feel with the OVER WEIGHT? You said the factory rod felt overloaded with the bigger weight?
Tackle-holic
Will take pictures in the morning no light outside, have rigged up a little rod holder jig so I can show the rod under load against a wall.
KR rod felt good with the 2oz load... 90m good...
Tackle-holic
Made some adjustments to the layout last night, will test again today to compare, added 1 more KT7 to the mid section and tightened up the reduction train. Will post photo or the revised reduction layout from my phone.
Tackle-holic
Adjusted layout:
45g lead 90m. much more would be down to better casting..
Description of photo included as part of post:
1. Highest rod shown in photo shows the blank loaded at the tip eye with 9oz of lead
2. Middle rod is the standard layout
3. Bottom rod the KR layout.
Before you get excited and assume more guides make the rod worse off, the addition of guides and change in layout have allowed for the more powerful butt section of the rod to come into play i.e flex.
This is the area where energy is stored.
Note that the blank in question has a parabolic bend i.e. flexes right into the butt section when fully loaded.
Tackle-holic
Tested an additional KR rod today:
Awa Shima Pursuit 9’ 8-25g
Fantastic rod if you want to drop shot/fish with soft plastics and a jig head and throw spoons and hard-bodied minnows be it off the stones or in an estuary . I think I might need one. Need, not want....
Test equipment:
15g: Rapala Maxrap 13
23g: Onde Onda 23g
45g: tear-drop sinker
Line: 8lb Berkley Fireline
Factory Layout
15g: 45m
23g: 68m
45g: 82m
KR Concept Ver 01 (Stripper @ 445mm from spool axle, choke @ 1040mm)
15g: 62m (17m improvement 37.7%)
23: 78m (10m improvement 14.7%)
45: 88m (6m improvement 7%)
For me the huge improvement in the lightest weight is significant, the Maxrap 13 tends to tumble at the end of its flight path as it slows dow.
It means that light jighheads with smaller soft plastics will be a doodle to throw 40-45m. Small bullet spoons will be a joy to throw.
The blank is sensitive and has heaps of power in the butt.
Chuffed.
That'll be a perfect rod for the Swartkops where small lures with light presentation is needed to sort a Grunter or 2.
The amount of performance increase shown on the lighter stuff is phenomenal. Just shows what a bit of research and fine tuning can do for a even a good piece of equipment.
Tackle-holic
I think the heavier weights are pulling line off too quickly.
You can actually hear the line rubbing against the rim of the SPOOL wrrrrr (no noise from the guides)
I have written down the guide-to-guide measurements of the reduction train so that I can revert back to them:
I have just moved the stripper and 1st intermediate guide closer to the tip to give the line more space to reduce its cone diameter (everything else stays as is) to see if I can MAINTAIN the light lure performance and further improve the heavier lure performance.
If the 15g lure performance suffers, I will go back to previous layout.
I would rather be able to throw a 15g Maxrap or 17g Strikepro Walking Stick to an EASY 50-55m than throw a 1.5oz spoon to 95m; there are rods better suited for the longer heavier job....
Nice to know that if you only take one rod down to the river it can do both jobs well.
Like I said, I need one of these rods...
Will just add to my list of must have rods! Will need to build myself a tackle room soon at this rate of "Need to have" rods.
Tackle-holic
Comparison of the two KR Layouts:
KR Concept Ver 02 (Stripper @ 510mm from spool axle, choke @ 1040mm)
15g: 60m (15m improvement 33%)
23: 74m (5m improvement 7.4%)
45: 90m (6m improvement 9.75%)
Looks like ver 01 was the better layout; moving stripper out improved the heavy casting ability but reduced the performance of the lighter weights.
I have reverted back to Ver 01.
Tackle-holic
Re bind of Shimano Beastmaster Dropshot 8’ 3-28g
As standard the 8’ Beastmaster was very disappointing:
Rod tip oscillated horribly after every cast; distance was way below expectations (read hopeless)
I would describe blank fast actioned; soft tip with relatively stiff butt, WITHOUT guides it stops dead after a good shake; convinced me that the guides fitted by the factory (especially to the tip section) were too heavy.
Test equipment:
Reel: Shimano Symmetre 4000
Line: Berkley Nanofil (measured average dia dia 0.23mm)
Leader: Berkley Whiplash 50lb (over the top I know but I wanted a worst case test)
Std Configuration (8 "Shimano" SIC guides + tip)
23g Onde Onda Spoon average cast 50m
45g lead average cast 65m
KR Concept Configuration (11 guides + tip - guide spacing, other than reduction train, set up only using static loading to get line to follow blank curve as closely as possible)
23g Onde Onda Spoon average cast 72m (20g Halco Streaker spoon threw equally as far)
45g lead average cast 89m
23g spoon 20m improvement (40%)
45g lead 24m improvement (37%)
Very pleased, have a lovely rod for fishing soft plastics as well as hard bodies and spoons. Sensitive AND capable of thowing far.
Tackle-holic
I would love the chance to have a chance at re-doing an Amia with a KR Concept layout.
I might be proved wrong, but I really think it would increase the performance of an already good rod to a level that would be incredible.
Tackle-holic
Nice depiction of the difference between ordinary guides and the high frame small ring KR Guides.
Tackle-holic
Anyone with an oldish rod they want to rebuild (themselves?)
Offer to a do a DECENT layout based on blank type; specific reel and line; will provide a drawing of the layout to make it all easier to build....
Drawing would look similar to attached Low Rider layout. Dead easy to use...
