Carll wrote:
Very interesting post guys ! I had learned lot how imported are the CORRECT Rod Guides. Keep posting !
Hi Carll,
K series are very versatile guides. You can rung it on a rod for fixed spool and multiplier reels. Because the fishing scene in Asia is spacious to execute casts deploying bigger arc, they have been tested with braid on rods with alot of bend. I personally have tried 6-7oz to test certain UK style rods, not more because we rarely use above 5oz even for fishing. This is my take on how it works:
The KW series has a thicker frame that withstands brutality more than the conventional MN guides which are used for multiplier. Thus these guides are developed to remove braid entanglement that are able to tear guides out of the rod or even on worst scenario press the guide feet into the rod blank. The tangle will shed and the frame will resist distortion. You will find them on factory built Century fishing rods too. Neither do these guides cost more than its predecessors.
I have yet to tangle any guides when casting multipliers on mono or braid. So it wasn't of much importance to upgrade all my rods to K series because we do not have exceptionally strong wind.
For fixed spool, which usually depend alot more on spiral flow of braid from those modern Shimano zero degree reels, we had to make the change. The reels are designed to dispense line in a direction zero degree to the rod blank. So while these reels feed line in a 'parallel to blank' manner, the guide has to control the over-run generated in the process. Even if the reel weren't designed as zero degree, changes are still made as the guides were much lighter compared to others.
When lighter guides goes on the rod, there are lesser load on the rod before you even cast it. If you had selected a rod capable of being casted, this is actually an advantage- more rod power without buying new rod. But if the rod is already overpowering the user, you may think twice.
So in a nutshell, this is how the K series works. Be it KW KR KT. I still use the lowriders as a bottom guides though for purpose unrelated to catching fish.
