Fuji KR Concept
OTGman
Tackle-holic wrote:
I am very keen to experiment
The 10'6" was not built on 27x spool dia principle, initial layout and choke point were adjusted and adjusted...
Was built by placing stripping guide to catch the coils reduce slap to 0 and then choke at approximately the same distance (slightly less) as stripper to reel as stripper to choke, no slap between guides, it works out at 19x spool diameter
I am busy experimenting with other non 27x choke points.
A St. Croix that I have just finished comes out at about 21x dia
27x works though if you are building a generic set up.
I think Tim Kirkman came up with 27x before the huge increased popularity in braid so could be more mono friendly?
You are right. The 27x spool diameter is a concept so that the reel can cast both mono and multiplier. 27x logic is something derived before lowriders/ K series appear.
When the line does not break (in his hands or whoever designed it), it doesn't mean it will never ever break on other people's hands. Quite frankly, I have been trying to use 27x because I do not want to reinvent the wheel. The more time/ money I waste, the less time/money left to use on fishing/casting.
Because I view 'flex test' and 'smallest guide possible' as top requirements, 27x logic never ever worked for me.
My unfriendly and direct opinion: Do not bother about 27x logic when using KW or LC.
Tackle-holic
With KR try about 20-24 for braid set ups....
Not suggesting KR is better than your current set ups, but worth trying..
For "bigger" rods try KL25H to KL12H to KT10 at choke then stress test the rest of the blank with KT10's, guide closest to tip no more than 130mm from tip
Can also try 25H to 12H to 8M to KT8 choke
OTGman
Tackle-holic wrote:
Any thoughts on a beefed up surf rod friendly version on the KR bait casting set ups for the multiplier boys out there?
No matter what guides Fuji invents, the most important thing to check is : Does a line of sight appear from top of reel to tip guide after taping them on. If you cannot see the opening of tip, you are 'deliberately thumbing your spool from start til end of cast'.
You will backlash more easier since the guides are hindering your line yet your reel keeps feeding.
For multiplier casting, build on guide that is lowest height but allow line or shockleader(if any) to go through. Low profile tournament cage for multiplier has been made to make the spool sit closer to blank. People like TG and other UK casters setup their own company to make such components to allow spool to go even nearer. This allow using guide with lower height which usually is lighter.
Lower height means closer resemblance to the natural curve of the blank- the way the rod is designed to be.
Before there is Akios reel, there are alot of people willing to spend 50pounds to buy a tournament cage to replace their original cage whereby the reel is only 100pounds.
In short, for fishing anything will do. For fishing and casting further, use lowest guide possible.
The rod below is meant for low reel, I put my reel high up on right hand, the tip guide cannot be seen. Conclusion: My camera is lousy.
kitefisher
May I ,without interrupting you guys whilst you are in your stride,just say that this must be one of the all time, most ''knowledgable-of-their-subject''-bunch of contributors,to any post I have seen on here before.
Jeepers that was a long sentence. Been following this topic since Post no1,keep it coming.
Standing ovation,years of collective experience in motion.
OTGman
What I use. For fast rod 10-8-8-10-10-12-16-20. Fast rod = 0-1 underlation after cast.
For slow rod 12-10-10-10-12-16-20. My leader is 80lb braid.
12 is always my choking guide. Stripper guide is always a lowrider 20. The rest all KW or MN.
Before that I am using KW30H, so I do not doubt KL25H won't work. My reels are 72mm diameter, some even more. If I can use KL25H I will definitely use. Why I change to LC20 has to do with field distance and action of my rod.
And if you want to reinvent the wheel, you should not take 27x, 17.5x or whatever as standard. Craig put on guides, defy the logic and end up with a better rod. All rods are different, don't bother with choking guide templates if you want to get casting weapons. I can assure you 101%, if you can choke viciously and end up with no fraps, you are good.
OTGman
And don't look at Fuji templates for building rod. It rarely works when it comes to European rods. My English poor. I copy/ paste what Fuji wrote.
4) The design of K-Series guides enhances the effect of “Rapid Choke” due to the 30-degree slope of the frame and ring. Fuji engineers do not claim that the slope makes Rapid Choke possible, only that the downward facing ring enhances the effect and contributes to overall performance. Because of this effect, Fuji has chosen to expand the K-Series product line as the guide frame of choice for KR CONCEPT layouts.
If you want more choke, take out all the guides you have and put on a table. LC, K, SV, HV, LN, MN whatever. Any model, any size, any height. Put 3 guides at progressive spacing on a broomstick and look through. Take measurement, next time go field, tape them after your running guides. You will have idea of concepts nobody ever think of.
OTGman
Tackle-holic wrote:
I am not a good caster, so would never criticize someone who clearly is!
And by the way, please post video of cast. Specify what rod, length, reel, diameter, distance. I will advise you on one specific cast that can break your current casting distance without swinging leads in the air. If you can do it, you will be able to do tackle test very efficiently and advertise your products showing you don't need brute force to go fishing. You cant use it in water but you will hit 150m easily with one hand.
Tackle-holic
Alfred, the rod Craig tested was not built to 17.5x or on fact anything x spool dia, it just happens to be the factor that comes out if you work backwards. (Perhaps pointing out the limitations of formula builds)
I think the point being made was the same as yours, whilst formulas help to build generic and functional layouts, building to suit a specific rod, reel and purpose can and often will result in some funky layouts.
The 10'6" was built to rapidly choke reasonably fine dia braid as quickly as possible (whilst avoiding constructing line flow and distance) and then to use as many as necessary of KT10 running guides to keep the line conforming to the curvature of the blank.
For throwing smaller sinkers and lures it really seems to offer good performance.
The line is quickly brought to a straight run and then flows straight towards the tip.
For really big fixed spools, I am not sure it will work quite as well, the only way to find out us to TRY
Tackle-holic
Ok will try to take a video for you to critique
Always keen to learn.
Any guidance on what set up to use?
My heaviest set up is a 11' with LC's
20 16 12 10 8 8 8 and MN8 tip
Reel is OLD Sustain 5000FB (really want to get a high speed grinder!)
Tackle-holic
Kitefisher, 2 things
1. I have always wanted to learn how to fish with a kite, keen to help?
2. Build a rod or at least rebuild an old unused one... (One you would use for casting not kite fishing) It's heaps of fun and the building journey and results at the end are worth the effort...
Tackle-holic
OTGMan,
Would you be keen on trying out a KR build?
Perhaps on an older unused rod?
Would happily draw it up a possible reduction train in AutoCAD for you to have a look at.
Would need some information about the reel.
1. Spool dia (72mm?)
2. Height of spool axle from blank (when spool is fully extended)
3. Distance from reel foot to spool axle tip
4. Angle of spool axle.
5. Reel centre seat to rod butt.
Come on let's try!!
OTGman
I don't critique. I only advise. Only people who can beat the person in their mirror can critique.
I have one unused blank left. A very challenging one. Its a rod called okuma tundra 15ft full e glass. 3 section. Bends from top to bottom no matter what reel you put on it. Rating 4 to 8oz but i can only cast 2oz on it. I will put any guide for u provided I have those guides. Sadly I only have the following. Mnst 12. Cmnag 10 12 16 20 25 30 lcag 12 16 20. Hvsg 16 20 25 30 40 kw12 16 20 25 30h
I have no sponsors so this is the stuff balance from casting group. I will video my measuring process of that reel so that u know data is not manipulated. What data of the rod do u need?
Tackle-holic
Not too much re the rod, just where you want to place reel for comfort/casting style.
You say full e glass so I assume it could be described as "slow"..?
Maybe the manufacturer was overestimating its abilities @ 8oz...
Would not be the first....
Any KT10's available for tip section?
Going to use braid? Diameter?
OTGman
You wanna find one that suits u for fishing is fine. Since the cast is not difficult to execute, you don't need a performance blank even. But general rule of thumb, you will not learn much casting rods in your comfort zone. Choose the technique u use to conduct fishing tackle test. The more you get knock off balance by the rod the easier for you to get pointers from people who knows about casting. Please do not put just slow mo video, it will deter anyone from viewing.
OTGman
The thing about sinker rating is practically who does the tackle test. If u have a fishing person do it, you will need a sinker rating up when buying rods that are used for fieldcasting.
See daiwa saltiga ballistic 40-405 or shimano aerocast 425bxg or beastmaster. I think if there are topic in sealine, u will know what are they. Who casted 8oz on them?
