[size=3][font="Times New Roman"]Good “All-rounde
AMG1
Pan
I will do the casting test with the following rods and will post my findings next week
13ft
Pond Master
Torpedo mk2
Bazooka
Blue marlin Electra
I wil also be testing 2 new rods that I got reasently
12ft Awa-shima V-max Spod 5lb test curve
12ft Awa-shima Outlaw 3lb test curve
Pan
AMG1. The results should be interesting...
Only problem i see with the Awa-Shima V-max, is that you wil have to load it with a HEAVY weight, seeing that it has a 5lb test curve.
AMG1
True that is the only problem but will be resolved with a p4 and 5.
The rest of the rods will have to do with a M2. I will also give the Bazooka a go with a p4
AMG1
Yes I can’t wait to get to the dam.
I have loaded a Shimano 8000gte with 0.18 Awa-shima Super Cast line with a 0.4 King fisher leader.
AMG1
Hi there Gents
Compliments to all for the new year.
Well here is my findings. 5 casts per rod
All casts done using a Shimano 8000gte with 0.18 Awa-shima Super Cast line with a 0.4 King fisher leader and a m2
13ft Pond Master – 138m All 5 casts was between 135m and 138m
13ft Torpedo mk2 – 132m
13ft Bazooka – 144m
13ft Blue marlin Electra – 142m
12ft Awa-shima Outlaw 3lb test curve – 151m fist cast
All casts done using a Shimano 8000gte with 0.18 Awa-shima Super Cast line with a 0.4 King fisher leader and a P4
12ft Awa-shima V-max Spod 5lb test curve – 174m and the worst was 168m
13ft Bazooka – 164m
AMG1
I must say I am still in love with my pond masters even with the distance I gat from them.
They are so light that I would be able to cast with them the whole day.
And I must say the v-max spod is a brilliant rod that I just need to get use to.
With a bit more time lots more meters can be added to that rod.
Pan
AMG1. Very interresting. You said my 172m cast with the Bazooka was great. With a 3oz bottle sinker you will beat that by far...
What about casts from some other members. No world Champs please. lol
AMG1
Thanx Pan
One thing I forgot to add is that the weather was perfect and the humidity was low.
It was one of the few times next to Arbaie where was no wind.
Yea guys how about some impute from some other members.
Naruto
Naruto wrote:
Enigma wrote:
2 Piece Blue Marlin G2 1-2 oz but I would go with 13' not 12'
The 13' has a great action and is suited to both Conventional and Specimen Angling
9 of our club fish with these rods and the can cast from a M0 to 125m to a 4oz (112gr) with small bol to 200m
6 of Our team that took Gold at the 2009 SA's in Hartebeeskuil and 4 of the B side that took gold at Bloemhof fish with these rods
The 12' Bazooka is good value for money bt casting lighter weightls like the M0 or 1 needs a very powerful cast to load the rod.
After the hailstorm which trashed Dean Pelser and many other anglers rods in Oranjeville, I can confirm that 2 piece is definitely the way to go.
You can have them custom made by Johan Louwies of JL custom rods at around R1450, with the 13' it's not necessary to get the softer T24 tip as the longer rod gives a softer yet powerful action
What would you say is a good weight for casting with the Bazookas? M2, P3, P4?
AMG1
Naruto is your bazooka a 12ft or 13ft?
The reason I ask is because I tried a p2 on my 13ft and got good distance. But my Pen mate (my dad) tried the same
With his 12ft and last a lot of distance between a p2 and p3. I think the 13ft is not as stiff as the 12ft…….Not sure but that’s
What I think.
Pan
The Bazooka, (12'), is not for small weights. I built a "Baby Shoes" with a M1 weight. Every time the bomb would come off. I then increased the weight to a M3. No problems, and good distance. You really need to load that rod to get performance out if it.
It does'nt really bother me, because i use this rod for Specimen, where i normally use 3-4oz weights.
The "Baby Shoes" was just a test.
I even tried spodding with it. Good distance, but i don't know if it will last, casting 150-200g weights.
AMG1
I must agree you have to load a bazooka to get performance out of it.
The past weekend I cast with my 13ft with a P2 and got between 97-105m
Grabbed a p3 and it increased to 114-119
Guys the casting ability of the rod is obviously important but a balance between casting, playing fish and you own fishing style all need to be considered.
My favourite all round rods my T53 13' G2 rods, custom built they fish a M1 to a 112gr distance lead and can cast a rocket to 100m. I use them in all facets of Angling and Max out at 185m with the rods but can cast a M1 with feed to 130m
My long range rod is the 3 piece Awa-Shima Skycaster. It casts a 112gr weight on 0.20mm line to 207m measured and on the league final I fished a line clip at 165m with an M1. I don't fish with them a lot but in competitions I have made the most valuable points of all with them - ie 2009 Trials I caught 100% of my fish with them and at the Nationals 2009 I landed 95% of my fish on them
For specimen fishing I fish 13' Prophets that have been modified with Fuji Low Rider guides (as on Tribal) and fish them with confidence from 30m to 130m. During the 2008 Trials Marius and I landed 564 fish out of 567 bites for a total of 1194.8kg they are built for playing fish and not long range casting
With the 5lbs VMax with a big Pit and 30lbs braid I can spod on a line clip at 140m and with a 4oz weight I can get up to 200m with 0.12mm braid. I would use the Skycasters but in Carp comps we are limited to 12'
For short range fishing I fish my Blue Marlin 10' Magnaflex rebuilt with shorter butt and new guides (and placing) although my son will swear by his SeaBass 10'
If I had to choose a single rod for casting and fishing I would go either with the Blue Marling T53 12' or the new AfriCast 12' 3.5lbs that I designed to give the same characteristics as the 13' but in a more affordable range.
@ AMG1, Badie and Marius Rusch are fishing full time with these rods now.
Misguide has these rods (12')and we test casted them at Arabie late last year.
They are light, well priced and with an extremely fast action.
With an M0 I was able to cast a consistent 124m and with a P4 a consitant 160m. I like the rod for casting but I don't like the action and I don't feel comfortable with the rod.
It needs a very HARD cast with a strong leader and not everyone is going to get casting right with the rod.
