[size=3][font="Times New Roman"]Good “All-rounde
AMG1
I saw the AfriCast 12' 3.5lbs rods that badie had with im the other day and they are Gr8.
When will they be available ? I told badie the moment they are available I want 2.
AMG1
I would love two T53 13' G2 rods but they are pricey. But I should probably
just look at them as a investment. And think of the fact that they can replace
at least 3 of my other rods.
I had a go with Uncle Pieters Skycaster this weekend and that is one vicious rod.
First go 192m with a p4 and .20 awa-shima line.
The first batch of the AfriCast Competition 360 landed last week and are sold out.
The next batch is landing in a sea freight and should be available next week.
Those red rods with such tiny guides are awesome casting machines but way pricey. But then again my top achievements in the past 3 years were all as a result of those rods. I caught when the others watched.
They cast from a M0 with a bol to a 5oz with a small bol.
AMG1
LOL yes please do not remind me league final was enough for me.
How far do you think were you casting that day? There was one other
Guy from your club that had a set of blue rods that looked almost the
Same. Are they the same?
Vleipadda
Call me ignorant - I see You all mention 12 / 13 ft rods
ive got my 16ft blue marlin carp rods , ( very slow action ) but I love them . Any reason why the shorter rods
Brakkanjan
Op hierdie stadium worry ek nie so kwaai oor die stokke nie, sal met my seuntjie van 3 se lucky packet rod vang net om by die water te wees. Gaan darem die naweek rivier toe (Vrydag en Saterdag) oh ja en ek is op verlof.
Ek hengel lekker met my 2 Loomis Carp rods (13 FT) Is seker tyd om te upgrade, maar die twee stokke het my nog net plesier verskaf en ek kom oor die 100 meter merk.Wil jy jou stokke gebruik vir kompetisies of sommer net lekker social?
My Sensation Carp Killer rods (10Ft) seker so 5 jaar gelede gekoop gee my ook goeie diens.
Ek dink dit gaan oor wat vir jou werk, want ek het al verder gecast met daai twee stokke as ouens met hulle stokke van duisende rande.
Ek moet ook bieg.....Dis altyd lekker om die beste, nuwe gear te koop.
Gaan jy vir die duur graphite of vir die goedkoper composite?
:SSS:SSS
Gertus
Interesting topig chaps.. as this is the question that has been keeping me up for the past year.. my quest to find the best combo... which begs the question..
SZurely its not the rods but the overall setup.. ??
I stated with 14ft loomis & F rods with two magnum sports.. i soon moved to thinner line.. this helped.. i then discovered a leader does help(12).. I then discovered a thicker leader helps even more. (17lb).. i then got shimanos DL6000.. did not get the distance i hoped for and went for new rods .. got the bazookas 13ft... better but something was not right.. then relaised the reels were "dragging" line on the cast.. and sold them and got me some GTE C 8000... so.. my concern is ..
there is a relationship between the spool size and the eye (guides) size.. if so what is the reasoning behind this.. ??
Enigma please put me outa my misery .. is there an ideal rod for a certain reel and if so what is .. best reel for the Bazooka 13ft and/or what is the best rod for th shimano 8000 gte-c's ??
Oh i use.. 7lb light green(or yellow) XX main line and 17lb Leader XX(dark brown)
Fanks
G
ps. what distance should i be getting with this combo.. ?
Optimus
Ask Enigma to built you good rods. My best cast today during a kol and distance throw comp at Nylstroom I threw a M1.5 witk a 12 feet Africast and .16 Tournament classic line of Awashima 152 meters. you will not found a better combo elsewhere.
Fanks
G
I use Shimano 10,000 on rods from 8' to 15' so your 8000 will be fine on a 13' Bazooka
Depending on what weight you're using
7lbs with M1 = 110m
5lbs with M1 = 127m
7lbs with P4 = 150m
5lbs with P4 = 170m+
Those are the New Alpha Tackle Rods (Oceanus) The blue ones are the lighter of the 2 and are around R2200 ea. Mark Cameron is the angler and we measured him at the casting rande and he fishes a M1 and bol on 0.16mm Super Cast at 160m (10 out of 10 casts)
The stronger one of the 2 is the Oceanus Tournament wich can cast, wait for it M1 with Bol to 6oz (172gr weight) It has a short 25cm solid carbon insert in the tip that prevents hook pulls. Around R2500 a rod and guys like Dean Pelser and Bessie Appelcryn are fishing these rods. Dean reaches 190+ with effortless ease.
I still like my Skycasters and it would just be wasting money to go get the Alpha rods now.
Deon Smit of Champion dips got himself a 4th in the SA's at Klipdrift, followed by a 2nd overall and selection to the National team using the SkyCasters in both events.
Boerboel wrote:
Graig what is the price and can I get them direct from you.
These rods as a result of their price and the aversion of freshwater guys to pay for rods are done on an order basis, in otherwords we don't hold much stock. The only guys stocking them at the moment are Ganis
Drop me a PM and we can help you via www.bluecity.co.za (we as wholesalers can't deal directly with customers)
Thanks Optimus. Just to avoid confusion here. It's not the AfriCast factory rod
it's a Purglas 3660 custom built that I did for Optimus's wife
If you have the G2 13' you can fish comfortably from 80-170+m eliminating the requirement for other rods
Pan wrote:
The Bazooka, (12'), is not for small weights. I built a "Baby Shoes" with a M1 weight. Every time the bomb would come off. I then increased the weight to a M3. No problems, and good distance. You really need to load that rod to get performance out if it.
It does'nt really bother me, because i use this rod for Specimen, where i normally use 3-4oz weights.
The "Baby Shoes" was just a test.
I even tried spodding with it. Good distance, but i don't know if it will last, casting 150-200g weights.
The 12' is a lot stiffer than the 13' as it has to do with the parabolic curve of the rod (all the small bends add together to make a bigger bend so a longer rod bends more)
To alleviate this and load the rod quicker and sooner make the drop on the 12' bazooka longer ie make it at least down to the bottom guide.
