Penn 49 for mussel cracker?
surfaMIKE
Howzit
Got a secondhand Penn 49 with a bakelite spool. I dont have another reel that I want to use for mussel cracker. Is my penn 49 ok to use for this purpose? Or am I just gonna get a hiding? Ive never caught a mussel cracker before. Ive read up on them alot, water conditions to target them in and so on, but yeah Im a little doubtful of my penn 49 holding up
Mike
Simen
Mike, anybody using a Penn 49 is def not looking for trouble, no matter what you are targeting.
Yes, its old technology, but before the new tech, those reels landed more fish than all the new reels put together.
Give it a good service, if you plan to put braid as backing on the Bakelite spool, first add 30m of mono and then braid. It will add as a shock absorber and a sponge to absorb direct pressure on the spool.
Def one of the best reels ever made.
TOE 007
good old trusty 49 , i have taken a few Crakers on them , and like Simen said the bakelite pops , i popped the Jigmasters spool .
For a dirty fight you need a dirty reel LOL
On_Dad
Agree with all the comments on here. Trustworthy reel. Would change the spool to a stainless steel spool though.
Those reels last forever
surfaMIKE
Thanks for the help.
Dunno where Im going to find a steel spool though.... I'll look around at pawn shops and so on. This reel is older than me by a good 10 years and its still in very good condition mechanically. Even the drag is smooth! Was just wondering if that bakelite spool would be up to the task
Im going to put 0.55mm mono on. Think that should be ok? The thicker the line, the less stress on the spool... thats my theory anyway
On_Dad
Pawn shops might have the spool. Is that the narrow or wide spool?
.55 should hold up. But those bakelite spools tend to get crushed with too much pressure.
surfaMIKE
Narrow spool
Me thinks the narrow spool is less likely to pop? Because there is less line putting pressure on the side of the spool?....
Dorado75
I recon there is nothing wrong with using one for cracker! Back in the day guys used to catch Yellowfin and bluefin tuna from the shore with those reels!
steve m
It is fine in my opinion!
the only possible problem is the spool popping but if it does it does but i doubt you will have a problem with it...
@simen i would say that braid puts less presure on the spool than mono as mono stretches so it puts more presure on the spool once youve put it on but however tight you put braid on is how tight it stays???
surfaMIKE
True that
I think more spools popped with mono than with dacron? So braid shouldnt cause as much trouble as mono
Thing is, I dont have money for braid, so thick mono will have to do for now. I prefer mono anyway
Shot for the comments gents
steve m
ya no i wouldnt put braid on for crackers etc was just an something i thought about...
alot of the older cracker fishermen i have seen use the 49 and hit the drag closed with a chokka mallet and have no problems...
will101
I've split a bakelite spool on a PENN 85 before while I was winching a fish in - I think you have to try and pump the rod as much as possible (wind in on the downward stroke) to avoid the line being wound up under too much tension. I found a replacement aluminium spool for that reel recently and now it's going strong again. Even after 30 years!
Simen
:SSS        Great advice given here.      :SSS
surfaMIKE
Yeah was thinking of the pumping action when winding in
Just opened my penn 49 open and she's as clean as a whistle! Gear teeth are all there, everything looks very good. A drop of thick oil in the bushings and gears and she is nice and smoooooth! The outside looks battered half to death but man the inside looks great!
The drag is smooth (??) but probably has a max of 5lbs of drag haha
guy4245
talking of popping Bakelite spools, i used to fly my kites on my Dad's jigmaster....one day in strong winds, i brought my kite in and the spool popped....lol
Marthin
if it's the wide spool it takes exactly 600m of .50 line.
If you are going for crackers, you don't need a big cast. You need tough and nasty.
I'd go with .55 maxima or alpha seagrand. A cracker won't spool you, the fight will be won or be over within the first 50metres max 100metres.
As long as you don't go less than .50 line diametre you won't pop the spool. All you do is take normal stoflap, gun cleaning cloth or a bandage and give it one nice layer of that stuff... after that wind away.
I also have the broad spool one, it hasnt a scratch on it. If you haven't casted with it yet, practise. If you are going to put the steel spool on, PRACTISE PLENTY! Once that bad boy is up to speed you need a thumb like the hulk to stop it!
surfaMIKE
Well I bought an OLD wide spool one a few days ago (has a bakelite spool too) for R100. Fiddled around with my two 49's and put together the best, least worn parts on the wide spool one from the narrow spool one and filled her up with 0.70mm 25kg nylon. Takes about 200m or so of the stuff but Im not going to cast more than 50m anyway. I want to drop my bait ontop of the rocks, and bully a fish away from them, hence the thicker line
Havn't cast with her yet, but it is a wide spool 49 and it will hurt so I should actually be practicing now
Thanks for the comments and advice
PS: Nothing wrong with this reel. Its like 30 years old and should go for another 20. By then I'll just walk into the next pawn shop and rebuild the reel again anyway
Marthin
mike, it likes a stiff rod and a decent weight and a smooth action. if it's on free spool you don't need that much effort to get it going. Do not jerk your cast coz it will bite back!
surfaMIKE
Very valuable info. Thanks!
TOE 007
i would go with the narrow spool , the wide spool gets a bit to bulky and hard to handle , if you have small hands .
Just another thing , you can pump the rod , very good advice ,
i would strongly suggest you [for Crakers] get a stainless spool , cause most Crakers are DAMN scally and they WILL find a place even if you cant see it and snagg you up .
My advice would be if you hook into a Craker , theres ONE WAY , straight to your feet . Pumping the rod WILL have consequenses , bad consequenses . Pumping the rod will give that prized Cracker just the lil bit of line to foul you up .
I do speak out of experiance , geez now i have opened up old wounds .....
