Over the past 2 years, i've had more bad luck with
Gavin Luke
A tip that I got from the guys at "Tyre Zone" the last time we got towed after a bearing broke up and lost a wheel. When standing between trips, jack up trailer and put on stands. The wheels are clear of the ground and no pressure on the bearing. It's a 5min job, but worth it in the long run. I check bearings grease every 3-4 trips, worth the effort for your pride and joy!
Can you elaborate please? I really cannot see why you should take the trailer weight off the wheels. Never hear of that before either.
BulkCarrier
I would think the oil get squeezed out where the weight is and it causes metal to metal contact and can make it start rusting or create a flat spot on the bearing roller in that spot
BulkCarrier
Gavin Luke
I notice it more and more now that it was pointed out to me. Have a look at your trailers wheel, they should be straight/flat on to the road. Some wheels have an angle on them, thats from standing for a period with the full weight of the boat on it. Causes a flat spot on the bearing, which leads to bearing failure. I'm just going on what the guys at "Tyre Zone" told me. Rather safe than sorry for me, suppose they could have said nothing and made a lot more money from me.
Serra Moz
Send a PM to Ski Scout (not often on Sealine) he sells bearing kits/grease guns ect. Or look on F/Book - Rob Welman (Durban or Richardbaai) Keep in mind I am not sure if he's still in the business.
Shaun17
OK... so i just accepted a job offer back in the sand pit (Saudi Arabia)... this now means my boat will stand for 10 weeks at a time.
Any advice on how to "store" a trailer....
Right,
I have done some research and spoke to the guys at Burquip. Puting the trailer on tressles is not really something done but I quote: "It certainly can't do any harm and can only be good for the bearings".
They also gave me the number for Rob at Axle Mate - he has a facebook page - http://www.facebook.com/pages/AXLE-MATE/124201894270196. He has offered to give us a full maintenance breakdown on what we should or shouldn't do. But I really think the fist step is to fit some axle mate bearing protectors.
Shaun17
benniejordaan wrote:
Right,
Bennie,
Appreciate the efforts!! Looking forward to seeing the maintenance breakdown and also keen on getting some bearing protectors!!!
BulkCarrier
Would love to know if they solved the stealing issue with the axls mates/bearing buddies. Won't last a week at the slip's in Cape Town. Too many boat owners around.
Ski Scout
Allo Allo folks
Bennie contacted me today and asked to post some tips on trailer maintenance...so let start with the axle and bearings
  1. I have to agree that some trailer manufacturers skimp when it comes to fitting the axles. I feel a lot safer having an axle ( and relevant size bearings) that can handle more (30-50%)than the GVM of the rig. It may be overkill but i do feel safer towing long distance through pothole infested Africa with something that can take the punch.[/*]
  2. You can aslo find , when buying second hand , that the previous owner wanted to save some bucks and went for a axle that will "Just" handle the load.[/*]
  3. If the axle has been through any bearing failure you HAVE to check that journal for damage/scoring to the seal seating area. Any damage here is going to chow the seal and in comes the water.[/*]
Right now for da bearings
What causes failure. In my experiance the main factors are A) Water into the hub B) lack of lubrication and C) poor quality bearings.
Lest start with lubrication(or the lack there off).
When the bearing is supplied it, is sealed in a plastic packet with a light coating of oil.The bearings have to be handled with clean hands and in a clean enviroment. Any grit or sand on your hands will transfer to the new bearing when packing ,and this can lead to premature E.......Failure
The bearings have to packed with a WHEEL BEARING GREASE so that all the void spaces between the bearing cage and the rollers are filled.
Now this is where some shops fail due to lack of supervision. They have a labourer doing this manually and it is not always checked that it is done properly. Its a K*K and messy job and when you doing bearing after bearing you get kind of gatvol...If that bearing is not packed properly with grease its going to cause damage to the race and roller in the first few K's of usage and it is just down to hill from there.Pretty soon you going to be stranded.
Even a poor quality bearing will last a long time if it is packed properly.I have seen cases where cheap bearings have out lasted top quality just due to the packing process being done properly.
Water ( specially seawater). How does it get into the hub , it is mos suppose to be a sealed environment?
Once the bearing caps have been removed , DO NOT RE USE THEM. Make sure they fit new ones. When removing them they get damage as the get moered out with a hammer (and sometimes a chisel)and the get dinged and dented. They will not seal properly, thus letting in water. When fitting new caps you can use some locktite to get a better seal.
Lets move to the seal(always fit new seals when doing bearings)
Damage can be caused to the seal by the journal(shaft).The Axle is made out of cast iron and the journal ends up rusting over time.This can score the seal and water will go in. If this is the case then you can take the axle to an engineering shop and have a stainless sleeve fitted over the journal(you would need a seal with a slightly larger ID to accommodate the sleeve)
Another form of damage to the journal is mentioned in point three of the axles section.IF you  had a collapsed wheel bearing at speed , 9 out 10 times the journal will be damaged , thus affecting the sealing ability of the seal
Another way water enters the hub is when a hot hub(especially braked trailers) is submerged . The cooling effect of the water creates negative preasure and water will come in via a damaged  seal or ill fitting bearing cap. Apart form waiting and hour or so for your hubs to cool there is not much you can do here.
Another way the water enters the hub is when YOU clean the trailer.NEVER EVER use high or direct pressure on the seal... a light mist spray or wipe with a cloth is fine. Using high pressure water can drive grime/water under the lip of the seal and that can cause damage to the seal , which will lead to water entering the hub.
Another form of water in the hub is condensation.This is minimal and not usually terminal. Most good quality WB grease have water resistant properties that will handle this small amount of condensation
The bearings
This is the difficult one to monitor and you have to deal with a reputable serving agent that can be held accountable should the paw paw hit the fan. There are guys out there that will charge you for a good bearing and fit the K*K one
Insist on getting your old bearings back  and they must be placed in the packaging of the new bearings. You now know that they DID actually change the bearings and that you have proof of what they fitted. Also Keep your job slip /invoice.
If you want peace of mind, fit a bearing protector.There are various models on the market and they suit all types of budgets.
If you going to order bearing buddies from the states , double check your sizing , they are imperial and we are metric.In my experience they only cover insurance to the point of entry (ie JHB) , if they get lost after after that , its your problem
If you get the plastic one's , by another set as spare.They do tend to crack or fall of over time, thus leaving and exposed bearing(normally at the wrong time).If this happens , don't just fit the new bearing protector and carry on .The bearing must be cleaned and repacked.
A bearing protector's function is
  1. Keep the bearings lubricated and make servicing a two minute job.All you need is a grease gun[/*]
  2. If  there is any damage to the seal the bearing protector will highlight this. It will push grease through the seating area of the seal and you can attend to the problem.[/*]
  3. The bearing protectors maintains positive pressure in the hub , and thus ( if under load/ pressure ) should not allow water into the hub when submerging a hot hob[/*]
  4. Creates a barrier(a wall) of grease between the seal and the bearing , thus making it difficult for water to get to the bearings(in a damaged seal scenario)[/*]
I have some more info on my FB page ,  but i will continue on the morrow with some more tips.Will cover grease( and the misconception that it actually melts in the hub during use) and storage/towing tips
Have a good evening ( and please excuse the spelling )
Best regards
Rob
Serra Moz
@ Rob, glad they got hold of you, I couldn't remember the name....... I can testify for axle mate.
Are you back in DBN?
Shaun17
Rob,
Thanks for the info mate... after my encounters with trailers i need all the assistance i can get!! I'm unfortunately not on FB, is there any other way i can get hold of you to order some bearing protectors?
Have some mana for your efforts!!!
fishystory
something a lot of people dont think about, and we get this problem a lot in the cape. If you load all your gear,fuel etc. on the boat , and tow it to the launch site, your bearings heat up, and if you add load ontop of that, they heat up even faster, so when you get to the slipway, make sure you take enough time to prepare your boat in order to allow your bearings to cool down a bit, otherwise you will be dunking a hot bearing into cols water once you launch, and if you do this a couple of times, the mettle will start hardening to the point where they go brittle and pack up the next hight speed trip you take to your fishign spot. same goes for washing the boat and trailer afterwards, let the bearings cool down before hosing them down.
Serra Moz
Very good point, for me it's only 10kms max to launching site - then the launching docs ect...so I have time. A Yank co-worker told me once, one of his bearings cracked or he noticed it when he came back from his daily Bass run on a lake in the US, when recoved his boat his friend noticed the wheel wobbling. I guess the watertemp could have had a factor too? Yes, so sure it's a good point to observe.
