Well its easy, just buy another R200 rod for consistant 120m casting then
In theory and mechanically a longer rod will cast further. When I go fir extreme distance I use the Saltwater Oval DC 12'but it is a 5oz rod so has about a 7lbs test curve and launches a big sinker a mile.
Otherwise I use my 15'Skycaster or Blue Marlin Supperslim 50-30-430 for really long range casting with medium weights.
It is a combination of:
1. Speed, Power and timing by the angler.
2. Lead Weight and Line diameter
3. Rod strength and recovery speed.
Once all these are in balance you will get the maximum out of the rod.
The difference between a R600 rod and a R2000 rod is often only 5m, max 10m (in the hands of the same caster) but those who know fish behaviour and structure will know that 5-10m is the difference between 0 or 5 fish.
Also if I can cast the same distance as you but using 80% less energy I will be more accurate and I will fish there longer.
Read my posts again, I have kept my cheap rods because they do already give me my 120m consistently. My concern was when I wanted to get further distance I went out and bought a waft for R1000 and to my disappointment I couldn't out cast my cheap rods.................
So I'll keep practicing and perfecting my technique and save up for a new set of "casting" rods for those comps when the fish are far out
Which WAFT's have you got? What I suspect is the cheaper rod is a soft slow action rod and the WAFT is a quick action which generally wants a faster cast and with these rods the more you put in the more you get out (keeping in mind that timing is key)
Willis wrote:
Best I could get out the Raging bulls was 98m...now I get ave 118m with 100g trace (m1.5-24g) you must remember,main line & leader thickness also play a huge role is casting far...I went from a 0.27mm to a 0.23mm main...with the next komp I am scaling down to a 0.21mm line which is 10Lb...But to get back to your other question- technique plays a big role yes,you gonna have to practiseNeltf wrote:
Why not get a pair of Dc180's?
This is what im scared of.
I have a R200 rod and a R1000 rod. My R1000 could not get me more distance than my R200 rod so lets say I try buy another rod brand for R1500 and I still only cast the same distance as my cheap rod.....what do I do then? still blame my casting technique or just admit that's these fancy so called casting rods that get advertised to cast 200m are a fraud and a joke?
How far can you cast with your current rods? what rods are you fishing with now?
Right, so I have been back at the waters edge to try and "load" my 11' bazookas. I wasnt going to waste mielie bombs so I used a 0.45mm leader with a 2oz specimen weight.
The best distance that I managed was 138m and my average was 136m.
I was casting with the weight 1/2 way down the rod and started the rod at an almost 12 o'clock position, flicked the weight out in a sort of "pendulum" motion backwards and let it rip!
I ensured that I took up all the slack line before I started measuring the distance.
Hi Willis, I'm not clued up on the M and P weights, but a 2oz is +/- 60g.
Next time I’m next to the water I want to play around with different weights to see if I can find an optimum and try and translate that into a bomb that will suffice and reach a desired distance. I’m thinking that a 2oz mielie bomb might be huge... I have never concentrated on casting further until now!
