A Bronzie trace is nothing special ...
I use a 2-hook (1/0 circle hooks) dropper trace with 2 small 3-way swivels (0.50mm diameter for hook traces and link section, lighter for your sinker link). Your mainline can be 0.40mm diameter - remember you are fishing in and around the rocks. About 30cm - 35cm from sinker to 1st 3-way swivel and the same to the next 3-way swivel; about 25cm hook trace lengths ... Some anglers use a small red or white foam disc float or tiny "medicine bottle" cork above the hook, but this is not really necessary ...
I use a 2 - 3 oz sinker - the ones with the nylon grips. If it does get stuck, a little pressure causes the nylon grips to "give" releasing the sinker ... or else a Bronzie will release the sinker for you if you give it a bit of line!
Pink prawn works well - shell the prawn, split it and secure with bait cotton leaving hook point and gape open and proud. With circle hooks, DON"T strike, just keep a tight line - you can reel in very slowly when you feel the "knocks" ... you'll know all about it when he's "vas"!
Remember you can only keep 2 and they must be longer than 30cm. Bronzies are great eating, but vulnerable to over-exploitation.
