Light tackle setup
AYOBA!
I saw a knot on you tube called the loop knot, easier than the rapala and much stronger...
found it...
http://www.youtube.com/watch?v=ba1qN8zJrUI
Limpopoking
found it...
Nice!... gonna mess with this a bit!
Incidentally, on Knot wars, one of the best terminal tackle knots (in particular to a hook) was the Reebeck knot, introduced by Barry Reebeck, a South African.
rbacht
I am itching to go and try the new set-up and the start learning about dropshotting / spinning. Any old dogs that can give any pointers where best to try and possibly see how it's done?
drkobus
AYOBA! wrote:
casting wrong or too hard could cut your finger
Draai jou rem styf vas as jy gooi. Dan kan die spoel nie draai nie. As die spoel draai as gevolg van die trek op die lyn, beweeg die lyn oor jou vinger. Dit is dsn wat die lyn jou sny. As die lyn nie beweeg nie, is die kans dat dit jou kan sny baie minder. Dit is diedelfde as jy ń saag teen jou vinger druk. Kan nie eindlik sny nie. Beweeg nou net die saag vorentoe. Jou vinger lê op die grond!
:kaykak
BluFlu
:kaykak
DRKOBUS is 100% right. setting you drag tight prevents line slip and hence braid cut. That said the weights you will be casting are such that I would not worry about this to much rather set your drag, otherwise you will forget and lose that biggum, and put a plaster or piece of plumbers tape on your forefinger. Viola!
AYOBA!
BluFlu wrote:
:kaykak
Cool! thanks!
Gadget2805
Hey! As for knot tyring, try this
http://www.animatedknots.com
Look under fishing knots for the Slim Beauty. Easy to tie.
There is an app available for this on cellphones as well. Haven't tried it yet as I have a BB. I just use website.
AYOBA!
seems to me that slim beauty knot will also do the trick...here is a direct link..
http://www.animatedknots.com/slimbeauty/index.php?LogoImage=LogoGrog.jpg&Website=www.animatedknots.com
rbacht
nice - I like this one!
Snoop
Hi, tied the snap swivel last weekend, but caused more problems than anything.lol. Went fishing for bass this weekend and tied on 12 lb flouro leader onto 10lb braid using the yucatan knot, and had no issues. Pulled 2 bass over 3kg's 1 over 2kg's and a few smaller. great fun. All on plastics.
