Light tackle setup
rbacht
hi gents,
I am looking at getting my first light tackle set-up for some spinning / drop shoting from the side - Lagoons / harbours / surf. I've been reading up a bit and have been down to my local tackle shop.
I've come across a 8ft Shimano Vengeance 270 XH rod (R400) and Penn Sargus 4000 reel (R650).
The idea is to get started with a set-up as indicated above and as I get better improve the gear.
What's your opinion on the above rod / reel or would you recommend I try and get something different for that sort of money?
I've also heard braid is the only way to go - is 20lb Sufix, 250m @ R240 a good deal?
Appreciate your feedback
AYOBA!
very nice combo to start with , practice your main line to leader knots when using braid, not nice to struggle doing them when busy fishing
rbacht
Certainly will have to do that as I've never used braid before....
rbacht
Ok so I went with the 8ft Shimano Vengeance 270 XH rod and Penn Sargus 4000. I've also gone for 15lb SpiderWire braid and Maxima FluoroCarbon. Now I need to get lucky when I go try this out
rbacht
rbacht
rbacht
The name I have no idea, but have gone with the knot the fishing specialist showed me when I picked up the new toys. Seems a pretty easy knot to be fair.
AYOBA!
I use the Double Grinner knot but the amount of turns is different for both lines...thinner braid 3 times more turns than the flouro
Snoop
Hi, just a question. If I were to tie a snap onto my braid and a swivel onto the leader and attach it this way. Do you guys forsee any problems?
Snoop
Hi guys, just a question. If I were to tie a snap to the braid and a swivel to the leader and attach the lines this way, do you guys forsee any problems?
neilg
Looking for shortcuts ?
Use the Yucutan or Bob Sands knot to tie leader to braid, if u will be using a short leader then put a small power swivel between leader and braid.
Leaders don't have to be fluoro, green maxima line also does the job pretty well !
Snoop
Haha, shortcuts are always good. The reason I ask is because i want to tie all my traces before hand, try different methods. Gonna start out with soft plastics and lures (recently acquired) and then look at cut bait. I just dont wanna be spending most of the day tying knots.lol. But if you guys forsee issues with that setup, i'd love to learn.
Limpopoking
The fewer bits of terminal tackle you have in your rig the better. No need for swivels if you put your plastics on accurately. I have lost fish to snaps before. I no longer have them in my tackle box.
I go from braid to flouro with an albright (or if the rig is heavy, a PR) then from flouro onto my jighead with a rapala knot or perfection loop. I keep my flouro short enough so I don't cast the albright through the guides.
Keep it as simple as possible.
