Leader Knott through eyes
Wesf
I am busy getting things together for a all round longer casting spinning setup. The reel will be a stradic 4000 with 20LB braid. I have been looking at rods of 9ft may go to 10ft. I was looking at the daiwa exceller  but am leaning towards a 9ft Loomis drop shot heavy. Both cast weights i think are 1/2 to 1 1/2 ounce. Mainly looking to use it in surf conditions and from rocks. NEED Distance. Advice?
I would like to know who has had issues with casting the leader to braid knots through the eyes??? I noticed the Diawas eyes were especially small. I would like to have a few wraps of leader on the reel.
Any input and or recommendations appreciated.
Wesf
Oh and while i'm at it.....
Quick change clip swivel, where is best, on front of Lure or in between mono and flouro leaders, +- 1m from lure ?
Simen
issues with leader knots are usually created by the angler himself -- using the wrong knot can give a rather large one and then have difficulty passing through the eyes.
20 lb braid (what dia) the dia plays a bigger role than the breaking strain.
Also no use fishing with 20lb main line and then wanting to add a 50lb leader, with braid as a rule you always try getting a leader which is weaker than your mainline
(thicker but weaker) it helps when you snag up not to lose to much expensive line.
lets get the mainline dia and then see what knot and leader to use.
Dingleberry
I fish mainly from boats but advise to use shorter leaders to facilitate the knot always being forward of the tip eye. I have lost many lures trying to use longer leaders. The knot deteriorates rapidly on passing through the eyes on casting. I have yet to find a foolproof knot. It seems to break just before the knot on the braid side. Since shortening my leaders, I have had almost no breakoffs at the braid side. All my breaks have been from teeth, or rocks chafing the flouro (+-1m) leader.
Wesf
I must say that is how i am used to fishing, bit since i'm using braid i would like to creaet as much invisibility between lure and braid. I suppose its a toss up between the to really.
SPIN A HOLIC
hey wesf.
there are lots of ways i suppose to fish 9ft outfits but you will have to experiment and see what works best for you.
ill let you know what i use and give it a go. if it doesnt work then try some thing else.
at the moment im using a 3piece,9ft shimano aerocast and a shimano sustain with 20lbs (.23mm) power pro braid. if you want extra distance then use sufix performance braid in 20lbs (.18mm).
leaders for the surf i use .60 or .70 if the bigger fish are around but .60 is perfect.
use a short piece of line but long enough that it doesnt pass threw youre guides when you cast. trust me if you cast it threw youre guides all the time it can lead to all sorts of unwanted head aches.
another bit of advise is looking at a 5000 or 6000 size reel like a spheros evan. my one i still use when i take a second rod and have landed some awsome fish on it and with the bigger gears it last alot longer than the excellers.
what ever rod you get look for something with a fast action tip and some backbone. just remember that some fishing trips have 10 hour spinning sessions so something light weight but that has the strength to throw upto 2oz is fine.
good luck.:wfish
Wesf
Thanks for the advise. Can I ask more or less what length of leader you generally end up with? I suppose around 1- 1.5 m?
I played with a stradic 6000 today and to be honest i thought it was to heavy with the rods i was looking at. I think on a 9- 10ft rod the 4000 will be nicley balanced.
I think the x heavy in the loomis will handle up to 2 ounce but feels really rigid. Maybe i am just not used to such a stiff stick? Is the extra 1/2 ounce worth it?
I nearly coughed up a lung when I saw the price of an aero cast, but damn they nice. Maybe one day when i'm big... ^^..
SPIN A HOLIC
try and stick to a 9ft rod and 1.5oz lead heads. often i will go upto a 2oz with a 7inch mcarthy jerk shad but a 2oz bucktail is hard work to jig. it has its place when the wind is head on or you need a good cast at a far bank.
a 10 foot is aslo hard on the wrists and can become an effort to fish with on windy days and makes the retrieve alot harder to controll when working a lead head.
and ja a 4000 with .18 braid is perfect but then just make sure its a good quality 4000 as some of the cheaper ones wont last if you fish alot.
Wesf
Ta, yip Im thinking the Stradic 4000 fe... Any other rod recommendations?
What do you find the spinning in winter like up your way?
Hope you dont mind me picking your brains so late at night.....ha
SPIN A HOLIC
hell must say we have excellent fishing here all year round so winter or summer it doesnt make a differance. you ust fish in another part of the bay.
loomis and franklin had some nice custom rods at one stage that were nice and then i suppose a passion stick is also not too bad.
Wesf
No worries found it...Sensation... no website for them though pity. May need to go to pe and see for some decent tackle shops. A tad limited here...
Dingleberry
Understand your concern about vis. Needn't worry though, I have used short leaders in places like the Maldives where the water is crystal clear. There was no noticeable effect on hookups. I don't remember the water in PE (I have not fished there much) being that clear.
One thing I have picked up on though, is the importance of the correct leader to lure connection. Consider using the Rapala knot or a protected loop with crimp.
jonathanw
Good day Gents,
I was at Western Accessories (Boksburg) the other day and just could not resist, got myself a budget drop-shop/ Light lure set-up for mozambique later this year.
Picked up a diawa procaster 4000x for R530 paired with a Diawa Megaforce xxh 9ft rod (R350) with a casting weight of 30-90 grams.
This set felt quite balanced in my hands, the rod is very stiff but has mega back bone and the reel is not too bad but not excellent quality.
My question is what braid to fill it with ?? The guy at W.A said i should half fill the spool with good quality mono as backing and then use 20/30 lb suffix casting braid as top-shot.
I plan to fish small stick baits, Rapalas, drop shot up to 1ounce jig heads and spoons.
What do you guys suggest?
Much Appreciated.
POSTHUD
Hi Jonathan,
Also just bought a new outfit Exceler 10ft rod (up to 3oz) and Exceler Plus 4000 reel.
I ordered Sufix performance braid (20lb) 300yds for spinning and Berkley Fireline 14lb 300yds for when using baits.
P.S Ordered it from Cabelas.com for R570 (both lines) incl. shipping. Bargain! The only down side is that it takes 8 weeks to get here...
Wesf
Thats great, thanks. I like the rapala knot as it leaves the lure to swim freely. I would like to use a quick change swivel with clip,do you think this may put the fish off if right in front of the lure? Maybe tie the braid to the swivel with a clip and then clip on to the swivel on the leader. If they small enough it should not be to much of a distraction.
I think I am gonna keep the knot outside the eyes, just see my finger taking a beating casting that braid all day. I suppose its only 1 1/2 ounce so wont be to bad....
Wesf
POSTHUD wrote:
Hi Jonathan,
I wonder what the import duties on stuff like that is????
