Hookclip on sinker
BigBen
How far do you bend back your hookclip to prevent unclipping during cast and ensure release when hitting the water?
camo shorts
Depends on how smooth a casting action you have,would have been my answer yesterday,
Was doing some casting practise last night and must say, the bump when loading let me rethink this.\
Bought some 3oz grapnels and the wires were bent 90deg perfectly straight so couldn't clip except to drop straight down, bent just the tip down
AnglerX
I like to bend them open almost to a 90 degree angle and bend the tip slightly down. I like to see the sinker unclip just before the downward arch of the cast as the sinker start to loose speed, but it doesn't always happen like that. That's just me and my cast but I do know if I leave the clip in the original full arch as when I buy it my unclip percentage drops to below 50% in general, depending on wind and water surface.
BigBen
The reason for this ? is that on 3 ocasions last week I cast with bloodworm.
Had a crap throw and reeled in only to find that the bait did not unclip on hitting the water. This was including a small cork float attached to the bait snoot.
I will in future now open the clip a bit to 80 degree to allow for an unclip on landing.Otherwise u'r bait becomes crab food.
Simen
When I clip I guess the cli[p eye is approx 60 deg, never actually thought about it, just checked the ones close to me now.
Make sure when your sinker hits the water it hits it with a limp line
Limp line --- think of it this way
When the sinker hits the water it immediately travels slower (upon impact) ("stops")
The bait is still in forward motion as it follows behind the sinker
Now when the sinker hits the water ('stops') and the bait is still in forward motion
THATS when it unclips
Now if you cast and keep the line to stiff when the sinker hits the water you are actually applying BRAKE on the bait and it cannot release (unclip)
We all tend to take up slack the minute our bait is in the water, count to ten, to ensure a clip release
BigBen
What I also did for the first time was to make the bait snoot 10cm shorter than the sinker.This could have attributed to the non release as the tension is more with the downward travel of the sinker to the bottom.
I normally have my bait snoot only .5cm  short of the hook to allow for the release whether mid air or upon hitting the water.
:fbash release bliksem..LoL
jaccil
I had to give this a little thought the other day too, when I realised the ones I had bought were bent at 90 degrees - obviously not sufficient to keep the bait hooked during the cast! I bent it about another 10-15 degrees which I thought would be the minimum to keep the bait hooked and ensure optimal chance to successfully release the bait.
If the hook is proud (with the bend open), it should release easily. I'm guessing you had the hook pretty well hidden in the worm bait though, clipping over the bait and not just the hook?
BigBen
Hi Jaccil
The one time the hook was in the worm and one time the hook stood proud(what I normally do)
I think it had more to do with the snoot lenght for not unclipping. When buying sinkers I actully open the angle to assist / secure a released bait snoot.
Joker
This happens to me also. I noticed that it happens most times when I'm using some big Sard baits. Perhaps the little hook gets snagged in the sard. Or perhaps the cotton. Who knows?
When that happens I do make some adjustments to the hook.
Elf 786
Mr big ben
try this and let me mo what u think.... some dacron and mustad  bait clip....
check what whould happen in the 2nd pic when the sinker hits the water. Because te dacron is not stiff it will bend, move, twist resulting in the clip moving which in turn unclips the hook...
flippy
Elf 786 wrote:
Mr big ben
nice tip.. ((goodp_t(((up((
ferrars
aquadementia wrote:
snoot length doesnt make a difference it only has to move the length of the wire the hook is clipped onto
It actually makes a little difference but just on distance: The bigger the difference between hook and sinker lengths means more slack nylon getting dragged along in mid air when casting = less distance
After you have cast there is nothing wrong with shaking the rod to help with the release
BigBen
@ Elf786 Where did you get those clips? Wouldn't mind trying.
You know we mostly deal in hypertheticals of the percentage the actual bait realses after casts.
I'm willing to try this. The noticing of this unclipping was a 1st for me last week thus the query.
To me the length of the hook snoot has 2 reasons.
1; Depth @ which the bait will float
2: Unhooking sucess rate of the bait on hitting the water in ratio to the lenght of the hook snoot.
Thus said we all learn nê. LoL
Elf 786
I Buy them at tuckers. what i normally do after casting is give my line 'skiet', remember, when it is clipped your hook trace is tight/firm so by giving skiet it will be more slap which results in it being free'ed-
