release bliksem..LoLI had to give this a little thought the other day too, when I realised the ones I had bought were bent at 90 degrees - obviously not sufficient to keep the bait hooked during the cast! I bent it about another 10-15 degrees which I thought would be the minimum to keep the bait hooked and ensure optimal chance to successfully release the bait.
If the hook is proud (with the bend open), it should release easily. I'm guessing you had the hook pretty well hidden in the worm bait though, clipping over the bait and not just the hook?
Mr big ben
try this and let me mo what u think.... some dacron and mustad bait clip....
check what whould happen in the 2nd pic when the sinker hits the water. Because te dacron is not stiff it will bend, move, twist resulting in the clip moving which in turn unclips the hook...
t(((up((snoot length doesnt make a difference it only has to move the length of the wire the hook is clipped onto
