B8FISH - Sorry Brendan, in my tirade, I missed your post...
Bro that is a fine set up you have yourself there!
I take it the Trevala is the 7ft version right?
Great thing about this rod is that it doubles as a great rod for fishing soft plastics offhsore, as well as casting spoons and small poppers while also performing well as a jig stick! Great buy. Especially as a starting out set up.
Of course the Stella is a Rolls Royce , so you know you got a killer reel there. My Stellas accounted for 6 nice Yellowtal yesterday,and on Saturday past I think 8 or more.. and the drags are just insane, still blow me away everytime. So you set there.
The Trevalla is 7ft right? This is great for a light jigging stick, because you can really get a nice whipping action to the jigs, as well as yo yo them... when one moves up to heavier jigs, you need the shorter rods to help with the imparting of the action...
So fishing ligt jigs, in the 80 to 150 gram range, that set up will be great!
What I would do perhaps though, depending on current/depth is maybe go lighter on the Braid. Although Jigman is nice and skinny.... if there is alot of current, you either need heavy jigs, or very skinny line.... SO if you have a spare spool, then maybe some PE 3 would be great, as you won't be fishing heavy jigs...
But for most waters, the 80 to 150 gram jigs are all you need.
For deeper water, and faster currents, look for longer skinnier jigs, similar to a Shimano Butterfly Longs or other tail weighted jigs.
These sink fast, and work well wehn retrieved Mechanical Jigging ( MJ ) style. Tropical Yellowtail and your open water pelagics, as well as Couta etc will like these. And you can work them from medium pace to blinding fast.
If you are fishing over reef structure, I like a centre weighted jig, which has more of a fluttering action on the drop, and a shorter more darting acion on the retrieve. These types of jigs ofetn get hit on the drop, so watch the line on the drop.
These jigs also work better than the long jigs on a slower MJ style, as well as Yo-Yo style ( up down with sweeps of the rod tip ) and can also be fished fast... They are great for bottoms like Rock Cod and Snapper.... But rememeber if you fishing close to the bottom, be prepared to turn that fish fast!
A good method to try over good reef structure, an allows you to fish the whole water colmn, is to drop your jig all the way to the bottom, then engage your reel and do a couple yo yo style sweeps with the rod, keeping th jig just on the bottom or a few metres off it....
If you get no action after about 10 seconds then start a slow to medium MJ for the first 1/3 to 1/2 of the water coloumn and then move the pace up to as fast as you can...
This basically targets 3 different fish/areas on the same drop... Its a great prospecting technique to see whats around.. You could pick up Rock Cod, Snapper and other bottomfish near th bottom, then maybe Tropical Yellowtail, Snapper and other reef cruising pelagics like Kingfish, Jobfish, and Couta with your flat out speed finish searching for speedsters like Wahoo and Couta.
If you know what species you are targeting, and where they are, then you can spend more time zoning a target area, but the above method works well for searching and prospecting.
One thing about jigging too, which shouldn't be ignored and is one of its biggest advantages.
Its quick to get a lure down, so if you are trolling or cruising and you are watching your echo/fishfinder and you see a ridge, hump, ledge or some form of attractive bottom structure, stop, and drop a jig.... sometimes all it takes is one drop to see if there are fish there or not.... take two drops, and if nothing happens, then move on... this way you really can put together a network of great spots tha will produce.
Hope some of this info helps...
Respect
Nepps
