Hi guys . I live in the Southern Cape. I have a
Kenty
Spooler wrote:
Hey guys.
Just wondering if anyone uses a baitcaster type reel when spinning for shad and garrick, and what rod you paired with it.
_seal1_..Jip....mainly for kob on spoon BUT use the same rig for shad....as you see in the pic attached....SL30...10,5' KingFisher Stimulator
frank22
this is a great reel for saltwater spinning and slow jigging.
http://www.jandh.com/daiwa-lexa-type-hd-high-capacity-baitcasting-reels.html
Spooler
It's hard to say. It looks awsome. But the proof is in the pudding hey. Historically baitcasters are for smaller fish. Just make sure you get a warranty and test the reel good and propper before it runs out.
frank22
a better video , have mine for about 4 months now. no hassles been in sand and under water , no signs of corrosion.
it is like any reel used in saltwater its gonna corrode , unless cleaned and stripped down and well maintained, it is a beast of a baitcaster.
https://www.youtube.com/watch?v=TK2I5MCWhPc
Kenty
:cool:..I spose as Spooler says ...time will tell....IF you gooi as much as I do . then rather go with the tried and tested reels , SL30 , TRG Shim....Speedmaster , ABU300C , Torium20 ....these reels have stood the test of time.....My SL30 is now 15 years old and never replaced a main gear OR pinion.....Ive worked on many of those Daiwa Lexa type reels....Even your R5000 Shimano baitcaster have all shown pretty severe corrosion...BUT....maybe just maybe...
I tell you what , not to be biased here , BUT shore conditions in SA are one of the toughest in the world as to opposed salt content , wind and sand.....
frank22
I agree with you Kenty and spooler but on the other hand with all the lastest technology , fishing has been brought into the future and new products need to be tested .the older versions of the lexa reels where specifically designed for bass fishing and other freshwater species.
The saltwater is very harsh on any material , caribbean , cuba, morocco , Oman, mediterranean and south africa are all heavy on metals.
As you say "time will tell" . Care and maintenance is the key.
fishersteve1972
Reading this reminds me just how spoilt for choice we are these days with tackle etc.
As a kid in EL had 1 reel/penn 180 for shad and was used for spinning from the shore, break wall or pier.Same reel used for float, drift or k bung.Fishing for mullet and leeries and catching livebait.
Got a 160 and a 30h for xmas when I was 13, gee was over the moon.
Kenty
:)..That may be , spoilt for choice , that is , BUT ...this TOO can spoil a new fisherman to this past time and he goes into any OR most tackle shops and all the staff wanna do is sell the prospective fisherman all the bling they can load him with.....Heaven forbid you are new to fishing , you then say you want to do drop shot...WELL....you could very well leave that said tackle shop minus R10000!!!
All too often , if a person wants a multiplier type reel , will need is a good quality reel thats affordable and a 12 to 14 foot rod that would probably set your back R3000 for rod , reel and some line....and then maybe R400 on some terminal tackle....he then has not forked out zillions and can slowly upgrade from there....
WaterKind
Well guys the last few weeks the shad has arrived in my valley. Been having good catches. Still younger shad but with time the sizes will only increase. Again the trusty Kingfisher 1V spoon has been the favourite!
WaterKind
For a few days about 2 weeks ago the shad was so "dik" the would be working on the water and you'll just cast over them and pull through and...... 'vas'!!!
I through them in a pool because every cast was 'vas' and then after just took my qouta and released the rest. (gave a few to an older gentleman who had a hard time catching them.)
Ben REINERS
More Alwyn.............dit gee my n hol gevoel in die maag om shad te sien wat gevang is op lepel...........dit bly "TOPS"............wel gedaan mater.(ni(ce(fish)(
WaterKind
Die gemiddelde groote van ons elwe is heelwat grooter die jaar hier by my. Hoe ervaar julle dit by julle verskillende areas??
Ben REINERS
Hi daar Alwyn......as ek kan terug gaan in tyd sou ek se 2014/15 het mooi groot elwe op gelewer op KZN kus.....daar was genuine n paar "busse" tussen in. Hierdie jaar van 2016 klink dit sover andersom........dis baie algemene/byna net-net lengte en selde n mooi grootte.
Ons moet seker nog wag v die klein blink-lyfies om n goeie verskyning te maak om beter grootte in elwe te sien....
die spook
Hi Waterkind
Het jy al elwe in die Suidkaap se riviere/mere op die Kingfisher 1V lepel gevang? Lyk my die rivier-leeries is meer volop in daai geweste.
Groete
