Hey guys. Recently i realised i like to spin , thr
roland
Hey guys. Recently i realised i like to spin , throw spoons etc. From the surf.
What setup do u use?
10ft loomis / powerspin6000 / 20lb strikewire
8ft vengeance / powerspin3000 / 15lb suffix ( this setup is sold now)
previn
poseidon 8ft gully hunter and slade 2500 fb with xaline 15lb
10ft loomis / convector 20 / 20lb double x
roland
New rod:
Kingfisher stimulator lite 10ft .
Will use the powerspin6000 on it for now, looking at the spheros5000 for it in the future
jomac
converted 8ft exage with stella 18000 80lb power pro
berkley air 9ft xh with sustain 5000 20lb power pro
crucial 7'2" with sustain 2500 4lb fireline
Mike D
I looked yesterday at the spheros 8000 to pair with my 10 ft exage, what braid is recommended, for the surf/rocks, if this is going to be my choice of reel?
roland
Anything between 30 and 60lb fireline for rocks. But dont you think a 8000 will be a tad bit off balanced with your 10ft? I would personally not go bigger than a 6000
Mike D
@ Roland - haven't bought yet, but would like to look also at the 5000 and 6000. Need the right combo and then braid also must be right choice.
Dexter
Hi Guys
With regards to Shimano reels. The 6000 and 8000 size is the same reel, its just the spools that differ. The 8000 has a deeper spool to take a bit more line and is usually lighter than the 6000 before you start spooling line onto it. Hope that helps.
Mike D
Dexter wrote:
Hi Guys
@ Dexter - great help, shot for the info!
kalf
exceller 862xh, diawa procaster 3000 and 15lb mustad dyna braid. Thanks to Khan, setup feels great to me!
tyrrell
9ft HMG Passion Stick, Daiwa Regal 4000 5iA, 20lb braid
6ft6 Passion Stick, Daiwa Crossfire 3000x, 20lb braid
BigG
I use a stradic 8000 on my exage 10ft, fantastic combo, no problem with balance, can cast it all day
2x spools loaded with 20lbs fireline crystal, 2x spools loaded with 50lb whiplash backing and 30lbs saltiga surf casting braid
