The Boatman
This sounds like PUI and not DUI
Posting Under the Influence::slo
but here is my brand new topic...for every fisherman too understand the easy way...let us start with the basics: the longer the rod the longer ur cast and the thinner ur line the longer ur cast and the heavier ur sinker the longer ur cast and the better u tune and set up ur reel the longer ur cast...and the better u load ur rod the longer ur cast and the better u excalarate ur cast the longer ur cast and the more power u use when casting the longer ur cast and the lighter ur reel the longer ur cast and the shorter u make ur leader or sinker trace the longer ur cast and the better u arc ur cast the longer ur cast.
...Listen leerfish man...Dont worry about all the negative comments...Come and join us on 365 Trendy Fishing FB page and I PROMISE you !!!...there the okes value good solid input!!!....It will be appreciated...SERIAS!!!!...Listen leerfish man...Dont worry about all the negative comments...Come and join us on 365 Trendy Fishing FB page and I PROMISE you !!!...there the okes value good solid input!!!....It will be appreciated...SERIAS!!!!
Shame on you DV, the guys hasn't even received a warm Sealine greeting, and you're poaching him already!
Admin"K"
..Sorry Boss!!!...Ek sal myself inhou!!!...:spitehello there guys sorry about my last topic..alot of guys got confused therebut here is my brand new topic...for every fisherman too undetstand the easy way...let us start with the basics: the longer the rod the longer ur cast and the thinner ur line the longer ur cast and the heavier ur sinker the longer ur cast and the better u tune and set up ur reel the longer ur cast...and the better u load ur rod the longer ur cast and the better u excalarate ur cast the longer ur cast and the more power u use when casting the longer ur cast and the loghter ur reel the longer ur cast and the shorter u make ur leader or sinker trace the longer ur cast and the better u arc ur cast the longer ur cast.
Just type decent full words and use paragraphs, makes it easier for us non casters to read & understand, no sms & mxit abbreviations!
Admin "K"
:clow:rastaguys i will ask my friends too take a nice casting video of me busy casting on the beach...then u all can see that i am not joking about surf casting 100+metets far over the breakers using 0.45mm line snelled up too 6ounce sinker..with out getting nasty backlash what so ever.u will then see the real deal...!
now let us start with the cast: stand up straight with ur feet close together take note this is only for right handed fisherman. now move ur right foot behind ur left foot and hold ur rod straight horizontal inline with ur body straight infront of u.now release ur reel clutch and hold ur reel spool with ur left palm and thumb and hold ur rod with ur right upper right hand ubove ur reel. press hard too lock ur cast. now slowly load up ur rod by moving ur rod very slowly backwards too the righthand side just as ur rod swings slowly back release a litle bit of line let ur sinker slide down 2feet in lenth..now lift up ur arms and rod up high over ur head and tilt ur back tip of ur rod in a angle so that ur sinker just touches the ground now excalarate fast forward in a smooth long arc loading ur cast smoothly up. please remember once u cast u must cast and move ur rod smoothly with ur sinker in the air and please always keep ur eyes on ur sinker .now just as ur rod almost goes over ur head now fast and smoothly release ur reel spool by just lifting up ur thumb sligjtly not too much and once ur sinker travels in the air keep ur thumb there pressing just a litle bit so u feather ur spool and reel lightly all the way through the cast. once ur sinker starts too hit the water press hard and aply braking power with ur thumb too stop ur spool ..guys i hope this helps but please contact me for much more better understanding and much more depth ....!!!
Leerfish man....jirre..... thats once moerse long sentence!!
Yoh!
:clow
