lushwill wrote:
i still prefer to catch with the handline but will always throw a spinner with the rod, but if the seals are around you dont want to be using a rod!Dorado75 wrote:which is the more convenient way to catch? handline or rod? :kaykaklushwill wrote:for handline you want a 42, 47kg or 52kg for bait, you can go lighter but when the seals are around you going to have hassles. Then you want a 60kg or heavier "lead line" this is for working a dollie or spinner. Get yourself a few different colored barrel leads and chrome, and some skirts, the hand made red ones are the best. You also want to get some 11/0 or 12/0 hooks with swivels for bait and a couple without swivels for the spinners and leads. You also need to get a selection of ball sinkers to use on the bait lines when there is a bit of current, get from the very smallest to big marble size. You can also use a spinning rod, something heavyish, i use a Shimano 20/40 on a Purglas tiger special and some Garfish spinners with strengthened hooks and nice heavy duty clips! And you will need a few vingerlappies and then you set to go!what is the tackle set-up for snoeking?
