Fuji KR Concept
Can't say I can feel the difference in the blank action. The largest portion of the change in price, as with all other things, can be put down to the ZAR/USD exchange rate. Basically cosmetic changes and maybe a bit faster action or at least recovery.
The last black blanks I bought were the same price ie R1300, same price as the new blanks
mouse .
Yeah I hear you, the prices where actually given to me by commercial marine here in PE. The price on the older 1s could be stock in SA and the newer blanks might still need to be shipped into SA through halco perhaps which would explain the price difference. The new blanks colour appeals to me. I reckon it looks cool colour wise. But like you say, the changes between the new and old blanks are probably only minor changes. (difficult to improve an already good blank I would imagine)
No the new blanks have been here for a few months already and I have built 3 and have 3 in stock in the workshop and their price is R1300
Tackle-holic wrote:
Anyone with an oldish rod they want to rebuild (themselves?)
Offer to a do a DECENT layout based on blank type; specific reel and line; will provide a drawing of the layout to make it all easier to build....
Drawing would look similar to attached Low Rider layout. Dead easy to use...
Yeah! I have an old 7 foot Shimano Carbomax baitcaster rod that I want to redo into a spinning rod for the kids. Can I use the existing layout on this sketch?
Tackle-holic
The sketch was just an example if how I do the layouts
It shows a low rider layout.
Will send you a legible sketch for a 7' spinning stick.
Pm me your email address
Tackle-holic
Nigel66
Hi OTGMan,
In an earlier post in this string you mentioned the Diawa Saltiga Ballistic 40-405 which you noted in your opinion had an exaggerated rating. I would be interested to know what you feel is the more appropriate rating for the rod.
OTGman
Nigel66 wrote:
Hi OTGMan,
Hi Nigel,
4-6oz
I bought the blank and used American Tackle Titan guides to make it very light to cast 5oz.
This is on 4oz. I only use low reel on rods which has butt capable of using my 2 hands to bend when resting it 45degree on floor.
http://www.youtube.com/watch?v=lLEvJPoSrzQ
I think you can find someone else doing a pendulum on it with 3oz in youtube. Most of the anglers at my end prefer to go for the 35-405 for fishing with 5oz+bait using a simple overhead. The difference between 3 model is the tip.
newby@beachview
Ok gents, VERY interesting thread you have going here! Bit too technical for this newbie, but extremely thought provoking nonetheless!!
May I challenge you to give me a straight forward recommendation as to what setup YOU would use for:
Spinning lures. In the surf only
Light as possible to do keep the arms going for LONG sessions
Lures from bucktails to plugs and dropshot - 1.5 to 3 ounce (maybe 4?)
Need distance for the big ones on the back bank, max needed, with casting
And still with enough action in it for working all these lures
What you say? Am I asking for a pie in the sky, or not?
I do not want prices, only your ideal setup for above. I have 1 recommendation already, but want to make the right choice for the investment I intend making!
Carll
The best rod for spinning in that class is the DC Oval 10.6ft
with KR rod guides.Its a AMAZING rod and cast 1oz - 4oz
lures!!That will be my next Spinning Rod !
Both my Assassin Amia and Assassin Spin E are now rebuilded
by Tackle-Holic with the KR Rod guides.He's playing now for
3 weeks with my rods to get the right guide sizes and guide
spacings right. Maybe Tackle-holic can tell us more whats
he doing :)
Tackle-holic
You beat me to it....
10'6" Oval DC with KR set up as follows:
20H; 10H, 8M, 8 to 9x KT8 running guides with a MN8 tip
Casts from .75 - 4oz
Light in the hand
Sensitive tip section
Great pulling power
Good value......
Guide train mentioned above allows you to easily throw heavy braid or mono leaders; 50lb in either material is no problem
Reel: 5000 size Shimano; Sustain would be best but if its too expensive go for the Stradic in a 5000. Next down in price would be the 4000 size Symetre. You loose some capacity but it releases line very well and feels smooth and powerful.
Unless you are planning to cast heaver braid, resist the temptation to use a heavier reel (6000 or 8000) they are MUCH bigger and heavier and are a real pain for all day use - I have an OLD Sustain 5000FB that is roughly the same size and weight (600g) of the new Sustain 8000FG its not great for all day spinning
Braid: 15-20lb Suffix 832 or similar, if you need tougher line and can sacrifice some distance (not a lot mind) stick with Fireline (latest version is improved I believe) in about 8kg (older lines will be marked 8lb, this is nonsense real breaking strain is over 8kg
The use of smaller reels with good drags allows us the placement of guides closer to the reel and and to use MORE guides.
Benefits
1 More power (brings the butt section into play)
2 More distance
3 More sensitivity (more contact points along the blank increases the lines vibration transmission)
