Fuji KR Concept
Tackle-holic
I am a tackle-holic....😄
Building a good rod is not obscenly expensive.
It can be... But does not have to be.
Read Enigmas comment about cheap guides destroying expensive line again. Carefully.
We spend our money on travel to a venue and buying the freshest bait and best lures and good reels and then lessen our chances for success by specifying cheap guides to save a couple if hundred Rand...
How much does a 300m spool of good line cost?
I would want to make it last longer
kopstamp
I only fish the best i can afford, mkre often than not i spend too much, but touch wood my "gear" bar once has never let me down on a fish.
OTGman
Tackle-holic wrote:
Always good to use the best you can AFFORD.
Would be nice if we could all afford a Stella or two!
For this reason, I would advise you to register yourself in forums of different country. Then look at the category in your interest. Because China is invading, they are copying alot of rod/ reel and presenting it with different decal/ color/ price. Even Powerpro braid, they also copied. I know how expensive the Stella is, we all want 1 but have we bothered to do our own research and find the right person to recommend?
A blank with the same power as the Blue marlin 80-430-100 is gonna cost me 85k-100k yen if I buy in Japan. 3 section too, rating 4-6oz. Both rod same weight.
A rod like Daiwa Saltiga Ballistic 40-405 made in Thailand for US market costs me USD458, a Daiwa Japan made model of similar power is gonna cost me USD800-900. Same tonnage, both HMG, 1 with accurate sinker rating, the other with exaggerated rating. Add in shipping and tax, I still save lots of money.
Enigma knows what I want, he recommended the correct rod for me. I enjoy being kicked by the rod and bending it (slightly maybe?) with 4oz at my current state of casting. I need to think on how to re-construct my technique.
Don't be surprised to know that Stella is no longer made in Japan but in a country where workmanship isn't that much expensive compared to Japan. Workmanship in Japan is very expensive, people are well trained and supervised but doesn't mean that all China factory cannot do same job properly.
So now you know why I am still here. On constant lookout for new innovations. :cool:
Brandon...... Kopstamp (Wessel) agrees 100% with you. His rods that I didn't originally build he has had re-done by myself.
He definitely knows the value of the right tackle and is a LC convert on his Grinder rods of which he has the 12' VMax 4-6oz and the 14' Blue Marlin Garrick 3-5oz and not to Forget his 4' Bushman's Special that throws a 3oz Plug and obscene distance for such a small rod (This one is fitted with BKWAG series)
OTGman
Tackle-holic wrote:
OTGMan,
Would you be keen on trying out a KR build?
Perhaps on an older unused rod?
Would happily draw it up a possible reduction train in AutoCAD for you to have a look at.
Would need some information about the reel.
1. Spool dia (72mm?)
2. Height of spool axle from blank (when spool is fully extended)
3. Distance from reel foot to spool axle tip
4. Angle of spool axle.
5. Reel centre seat to rod butt.
Come on let's try!!
1. 7.2cm - .28mm, 7cm - 0.21mm (All braid joint to 0.55mm braid leader)
2.  10.8cm
3. I think you meant bottom end of axle to blank. 11.8cm
4. 2.8624 deg. Bottom of reel to tip is 20cm. Angle = inverse tangent [(11.8-10.8)/ 20] If you live near the engine, you will know how I derive this.
5. 80.5cm
Last thing I need to remind you. Don't go and plug in my values into
http://anglersresource.net/GuidePlacementSoftware.aspx
You will end up with a concept that
1) I already tested and failed miserably
2) end up getting nonsense values with choking point above the rod which only bionic eyes can see if I put that reel on a 12ft surf rod.
3) I have a few rods that I can choke even faster than what the software is showing
Any system that you can use on any surf rod is a fool-proof system to build surf rod. I am not interested in systems that works in performance blanks but failed miserably on slow rods. Performance blanks are for those earning a salary by landing trophy fish or casting world records. Not everyone can afford.
I use a MN10 instead of KW10. The wind here is not strong, I have never tangled the tip or running guides if I follow what Enigma says '1st guide 12cm away from tip'. If it tangles, it's because my cast is jerky. All fraps is on stripper guide if any.
Tackle-holic
Point 3: was wanting the distance from reel foot (centre-line) to tip of axle.
This allows me to position the reel on the rod (graphically) knowing where it will sit and position the tip of the spool relative to this.
Are you an high or low position caster? (reel position)?
If up, where do you like the reel seat to be positioned? I know the the Asian standard seems to be about 88cm, but it might not suit your physique.
If low reel, how much butt do you like to have?
OTGman
3) 16.5cm
Keep the rod to high position. Rod has EVA foam at butt which I don't wish to remove.
Even if you mount the reel seat at 88cm, my left hand will grip higher and result in 80.5cm. Fuji suggestion is more for Japanese style of casting, wide arm grip to keep reel far away from body. I adopt other means of casting, pushing hand away from body using muscle memory to unwind.
Tackle-holic
Hi Alfred,
Couple if questions:
Tip and butt dia?
Rod seems to be quite heavy at 41.5oz/1160g, it's mass and length might weigh against it in that it could prove quite difficult to move quickly.
Okuma say it has a quick tip, are they saying flexible and sensitive or quick recovery?
Curve under (light) load? If say you fixed the rod at top and bottom hand positions and hung about 200g from the tip. Where dies the bend start roughly? Half way up the blank?
Brandon
That's heavier than a 400/8 Purglas which unfortunately doesn't bend when you hand a 250gr weight from it.
OTGman
Tackle-holic wrote:
Hi Alfred,
Tip and butt dia?
Brandon
tip-4.5mm, butt-32mm
200g, Bends at the top most joint, its 3 sect. I don't wanna cast 8oz, please have mercy on me. I know I am not big size. Anything 1-5oz.
It's not fast tapered, its parabolic the last time I saw it being casted. Sorry I don't have his photo. I just collected from him, he said 'go ahead and break it'. He will make a gaff out of it if I can break it.
It will bend throughout on 4oz. I got turn off by it and told you 2oz, maybe I really can do it. As for the top 1/3? Reminded me of carp rods.
I think Enigma would have casted many of such rods 20< years ago when I don't know how to use surf rod yet. It's a very old school kind of rod, like those from my granny's era.
This is a test of modern guide technology on old rods. You should truly be thankful Blue Marlin or Purglas don't make such rods for you. As to whether I can cast fast, I have to since I already agreed to test your concept.
Tackle-holic
Okeedokes.
Re the fast casting, was thinking bigger slower rod can't be moved through the air (at least by someone if my size and strength) as fast as say a lightweight 12 or 13 foot 😁
Slow down the 'swish' and let the length do the work...
It does sound like an old school carp rod.
Let's see what we can achieve with 1.1kg of glassfibre
cause it's fun to try....
kopstamp
Casted a similar rod in concept from purglas- heavy glass rod- casted a 9once with heavy leader. Found a a fast cast is a big no. But a controlled cast with a dash of speed right at the end gave a nice whip to it and produced satisfactory results. By no means super distance but well above average. Maybe a similar action would result in a good cast OTGman?
OTGman
Well above average? So do u find rod with glass allow u to cast easily if they are not so heavy like mine? S-glass is much lighter which I suspect your purglas rod is made of. The rod I have is e-glass and I really dont think it will cast 8oz being at that 1.1kg weight.
I know of a 400g s-glass rod that can handle 3-4oz. So probably the weight will indicate what grade of glass they used.
OTGman
Tackle-holic wrote:
Okeedokes.
Just assume I m small man with long stick will do. There had to be a way for small man to fish with the elephant but I will figure out.
And I just figured out. I will use this
https://www.youtube.com/watch?v=CHqVu3A48_s]
kopstamp
OTGman- this rod was heavy, don't quite think 1.1kg but up there. The rod was the only rod my friend had and he also wanted to fish sharks with us. So I put a torium 50 on and threw in for him. The other guys were getting 60m tops, I got about 85-100m on various casts.
I will see what I can find on that rod, it was a /4 if remember correctly, the it self was very thick.
