I received a pm from a member regarding fishing this spot with nice deep water. I decided it best to post my reply on the thread as well. It's a challenging area to fish and I'd rather provide a fellow angler with the right information than withhold information that could lead to him getting hurt.
Hi Stefan
I'm new in Cape Town and I'm looking at save fishing spots, may I ask where the spot is that you mentioned on Sealine recently.? Looks like a nice deep spot. I would like to go tomorrow, big or low tide?
Kind regards,
X
"Hi X
The mountain area outside Gordons Bay is definitely more safe than the False Bay Beaches. There are some incidents of theft out of motor vehicles, but if you follow the rule of "out of sight, out of mind" and hide eanything that might look valuable in your vehicle than you should be fine. The big big danger about the mountain area is the terrain. Please be careful!!! There are steep and unstable loose rock pathways down to different fishing spots. You fish from ledges and high rocks 2,3 or 4 meters above the sea. Yes, the water is deep so you're okay if you fall in, but if you hit your head along the fall, you're going to drown. Think safety first here! Watch the sea for a few minutes to see where the waves break, look where the rocks are wet from the waves, think where you're going to land your shark and how. Have a back up plan!!! NSRI numbers, first aid kit and a RTB (One of those plastic tubes with a rope that the life guards use). I've been present when a fellow angler fell in while gaffing a bronzie in a bronzie smash! Terrifying experience for everyone involved...
That said, the mountain is a great place to fish with many big fish landed and more lost there.
I feel it my responsibility to also inform you about the tackle I recommend. Going for sharks - your heaviest setup you have! Heavy rod - Pentagon Heavy HMG, Blue Marlin 7 + 1, Assassin Blade HMG, Solid reel - modified torium 30 etc, 0.55 or thicker main line, 1.2mm leader. Even the small bronzies of 20 - 30kg give you a work out! The water depth is 10m plus so even when the shark is at the gaff you're pulling up so no back support. It hurts trust me! Barbless hooks. You often loose fish by being cut off, or you cut your own line after 4 hours on a black stingray that you're not winning or you can't gaff a fish and have to cut the leader. With barbless hooks the hook falls out.
It's an intimidating place to fish. You cast with a drop off in front of you and behind you so you're on a perch. Where you stand, you stand. No running casting or loosing your footing on a cast or you're going to fall of your casting rock. You're pulling a shark capable of pulling you off the rocks and into the sea should your foot slip or drag stick, this gets even more likely when you're taking a shark around the point at buoy 4 to land it.
If you're still keen to go fish this area then go for it!!! Don't fish alone and use your common sense and you'll enjoy it.
So to fish that spot I fished - Buoy 4.
Weather - South West or North West for a day or 2, but not too many days as it makes the water too warm. Swell - not bigger than 3 - 3.5 for Buoy 4. Tides - does not matter, the water is too deep. Morning and later afternoon is best. Sea should have foam line running past the spot then you know the conditions are good. This is for the summer months. I haven't fished it in the winter.
Mostly bronzies and black pylies caught here with the odd small hammer head. If you throw for them, there are also a few smoothhounds around.
Hope this helps."
