Hi guys.
what do you think of the following combo for a starter, or should I go bigger?
Will be using is for light lures and bucktail jigs.
Daiwa Megaforce-A Spinning Rod MFA 702MRS 7ft, 2 piece, 6-14lb line, 1/8 - 3/4oz lure. Megaforce offers quality contruction and components plus outstanding appearance.
Ultra-sensitive pure graphite blank with non-glare matt finish
Lightweight guides with crack-proof, chromed stainless inserts
Natural cork handles with protective, composite cork butt cap and grip check
Strong blank-through-handle construction
Daiwa CrossFire CF 2500 3iE Spinning Reels offer a hugely impressive reel for the money and one that both experienced and inexperienced anglers will have great pleasure in using.
ABS Anti backlash System
Twistbuster, Infinite anti reverse
Three ball bearings
Reactive drag system ,Soft grip drag knob
Tin plated Steel ball arm
Ideal drop shot reel.
Gear ratio 5.1:1
Ball bearings 3
Weight 294g
Capacity .25mm/190m, .30mm/140m
Free spare spool.
Three ball bearings
Gear ratio 5.1:1
Ball bearings 3
Weight 294g
Free spare spool.
