century kompressor sport
OTGman
kitefisher wrote:
Thank you OTG. So it is safe to say that the KOMP-S, fished from low reel position would be fine for an Ultegra,and even slightly better for a Bullseye because of the angle of the Bullseye-shaft.
Without going into detailed measurements,the butt section would be 2.1 meters long and the standard guide is 16 inches(plus minus 40 centimeters) from the top of butt. That would leave 1.7meters to the bottom of butt.If the reel-seat is then placed at 350mm -400mm from the bottom it would leave the reel on the Komp S with roughly 1.3 meters to the first guide and may just ''work''even if it is a KWAGss30.??
p.s OTGMan I intend to rebuild the Zziplex M4 EVO, But in the meantime I would like to make a couple of casts with the KompressorS and the Bulls-eye,and Ultegra 14k.
Yes, if it flies without line slap or wrap it is good. No need for reducers. 1.3m is for people who want distance on those Shimano reels. BE XT is a model we have, from what I know 1.3m seem to be giving better distance for our rods here with both KW30 and LC20. If I mount a big pit reel from Europe, I may end up with 1.4m-1.5m. I don't know if you will buy any bigger or newer reel, if you have a habit of changing reels often KW40 is safer to use. That is why Century always can't answer question on fixed spool+KW30. Too many variants of reels around, it makes sense to consult the reel manufacturer.
kitefisher
_seal1__seal1_
