Tackle-holic
How do you like the 5500 XSB?
Does the spool shaft run parallel to the blank or does it appear to point at the blank?
Hmmmm I think this forum has members that know more about Big Pit / Surf Spinning reels than Shimano rep does when it comes to THAT sort of information...
They will sell on number of bearings, X-Ship and slow oscillation. I doubt they will have any clue as to what we are referring to or why it is important.
What do you think Shimano's reasoning behind the zero degree shaft is? Cant see how it helps performance myself, but am happy to learn.
Ballerina casting being the result?![]()
An interesting observation:
Whan I was experimenting/comparing KR layouts to "other" layouts a while ago, I found that more guides resulted in the bend starting earlier in the blank with the same load.
Leads me to believe that more guides result in more of the blank being used hence it bends a little more, but because more of the blank is doing the work, casting distance AND fish fighting power increased.
KR reduction train guides helped me bring the guides closer to the reel without causing bunching, lots of KT's on the mid and tip section kept line close to the curvature of the blank
Bulls Eye XT will work with KW30, point the shaft at the centre of the guide.
This would mean that theoretically the line would have to ''fight'' to get into that first guide if:
A) The first guide is not moved further.(not ideal)
B) The first guide is not increased in size,to 40mm/50mm
C) The first guide is not ''lifted''slightly higher.
I will do the same test with the Ultegra 14k and also the 5500 tomorrow,and post results.
p.s I suspect it would work ''fine'',yet ''fine'', is not necessarily optimum.
Alfred quote ''
If I were to choose, I will build the rod based on the ultegra and your other reels will have no problem''unquote.
This makes sense,but (forgive my ignorance regarding guides and guide-set-up), how does one build a rod with a regular reel-seat for fishing, to angle a parallel-shaft(zero degree angle-shaft),into the first guide.
The only way I can see you achieve this desired angle towards the first guide, is to raise the rear of the reel-foot by a millimetre or two.
For example,the Ultegra 14k has a parallel shaft angle at 103mm above the blank.You will either need some lifting at the back of the reel,or one hell of a ''circus-Lion-hoop- ring-size-first-guide'' for the line to enter that first ring....or alternatively, a very ''high-standing''-guide..
Somebody please help me,and be gentle, I admitted my ignorance![]()
