century kompressor sport
subaruseun
kitefisher wrote:
subaruseun wrote:
Simen wrote:
Had a look at the video, looks great, personally just dont like the adjustable reel seat, but nothing that cant be modified here.
Hi OOm.
i have been fortunate to acquire three centuries (rods)... two models standard and another customised with a fuji winch, so no issues there.
i intend customizing the kompressor for league fishing.
Subaruseun.. If you do the ''roll-test'' on any of your Century Kompressor Sport Tip-section's,do you perhaps also feel another ''spine''immediately opposite the spine where the guides are mounted(or anywhere else for that matter)
i just did on the G5... cant f"eel" a spine at all... what should i be looking for?
No prices on LCOG yet, that is all subject to the numbers we will be purchasing.
But probably half what Alconites cost
Tackle-holic
Craig could correct me but why would low riders be grinder specific?
Have attached a (Fuji sourced) layout for a 3.2m bait-jigging casting rod that uses low riders. Busy with a 7' bait caster that uses low riders as well as an (experimental) flyrod that uses 2 low riders as the stripping and first reduction guides. Have taped and cast the thing and the rod really out-performs the conventional fly-rod building logic.
OTGman
Tackle-holic wrote:
Alfred, do you really think dropping from LC/low riders to K series looks ugly?
A Ferrari F14-T Formula 1 racing car is not in the same beauty-race as say a 458 Italia but its performance makes the looks "sensible"..... and hence it is beautiful in its own right.
Smaller K series on the tip look quite good when preceded by a LC reduction train I think....
No mate, I do not judge performance by appearance. Fishing is about luck, you can cast 30m on a 6ft and sometime get fish maybe more pests. If the hybrid build allows me to do violent casts even on windy days, line intact, guides not deformed, I'd probably land a fish. It all means that the setup is forgiving and less hassle to fish with. Very sure anyone new to fishing will fish happily with it even if they don't have a smooth cast. Low guide height, less rod twist, more accuracy. When I say low height, it is in comparison to the SV and HV guides of the past.
Tackle-holic
Good man. Good engineer...
Form follows function.
Line up a low rider reduction train with a KT running guide-train...
Looks cool. Works well.
The UK rod market still staunchly follows the Cone Off Flight principle and like to go with a #50 or #60 first guide.
The Shimano Tribal rods with LC's were never accepted in the UK but are top sellers throughout Europe.
I have 2 rods, multiplier only that are fitted with LC and throw up to 1.8mm windons no problem and they make the rod into a monster.
If the rod it to be primarily a Grinder rod then I still prefer the LC setup. To get K series to Optimum on this for Grinder then you would be starting at a #40 and this becomes to high for a small multiplier so you would go down to a #25 or maybe a Low #30 but then it is again not the ideal.
You say you have more than one. Best might be to rather let me send you a set of each.
Lay the rod out with the one set and do 20 casts with a multiplier, throw out top 4 and bottom 4 casts and average the remaining 12 and then repeat the exercise with the other guides.
Low riders however with the wide foot spacing it makes it possible to use less guides to effect the same hook setting and lifting ability as a rod with more Standard guides on it.
Tackle-holic
Cup of water tipped over falls faster than that through a funnel?
Tell that to a river; as a river channel narrows the speed of (water) flow increases
I think my hand would fit through a size 60 guide.
OTGman
subaruseun wrote:
OTGman wrote:
Yes, there is spine. Even if no spine is detected from deflection test, there will be a softer axis that the guides tend to roll towards when doing light casts with tape on guide. Try locating using multiplier, it's more accurate without all the twisting from higher stand-off from fixed spool guide system. Then rung on the opposite side of what you've gotten on multiplier.
thank you for an informative post, it solves all the issues/concerns i had. my reason for asking is that the newer kompressors come with k series guides and the web refers... ""suitable for both multiplier and modern fixed spool reels""
so would assume its a hybrid situation catering for both multipliers/ fixed spools?
Yes. It will work fine with both.
OTGman
Now they claim to have arrive at guides better than SiC. Looking at the mudhole catalogue, they are pricey.
http://www.youtube.com/watch?v=z9YEpAFmlnE
Most probably I would have changed the lines even before they had a chance to wear out to such degree. Enigma, how often do you guys re-spool new braids?
subaruseun
thanks guys this was very informative...
after watching the videos reading all the info, im not sure why we haven't switched yet.
Craig. the way forward?
subaruseun
spine response from century...
that many years ago when rods were made on a much more simple composite architecture – the spine on a rod was much more defined. With multiple part pattern construction – this has to a greater extent disappeared – well it has with Century rods.
The old idea that you build on the stiffer side of the spine for heavier fixed spool guides is no longer relevant. K guides also eliminate the need for different sized guides and modern day multipliers have such good line lay that with the correct line – coiling is almost reduced to zero.
Your enemy always with using a fixed spool reel is line twist and you will need to consult your reel manufacturer on how to avoid this.
Best wishes
Tackle-holic
Sounds good, but they have to start wrapping the cloth at a point on the mandrel
to me at least a "line" down the blank will be thicker in terms of wall thickness.
Difference may be slight but can't see how you prevent this...
That line is the spine
OTGman
Best wishes
Thanks for sharing, I know the newer range such as Excaliburs, the spine is almost non-existent but not for the Kompressors. I think you will have to ask them specifically on the Kompressor S, because the reply they gave you is a general statement. I am very sure the Kompressor S has at least 1 spine.
I do not know what reel you are using, but generally KW30 is fine for braid IF 1) the reel is placed 1.2m away or more 2) with the reel shaft pointing to the centre of KW30. Reels like Ultegra XSC have a parallel spool inclination and not possible to achieve 2nd criteria. Such reels you will have to cast and find the position. Fast dispensing reels (slow oscillation) with larger diameter will incur tangles easily(>7.5cm diameter). Such cases you will really need a KW40 because the Kompressor S is a rod that has alot of bend at the butt and require a taller guide to keep the line from snaking underneath the rod. KW is not foolproof, if the rate of generating it is faster than the rate of removal there will still be tangles.
Some casters are very powerful, they face more problems than general anglers. To understand this, place the rod butt pointing 45 degree on the floor and rest on your right hand. Use left hand to push the rod butt. If you see a deflection of more than 5cm, go for KW40. This is also a criteria to know if the butt is too stiff to get distance out of it.
Tackle-holic
Hi Alfred,
Re the Ultegra XSC remark as to parallel spool inclination / zero degree shaft angle:
Does this pertain to all models i.e 14000, 5500 and 4500?
I have not had the opportunity to measure one up and am looking at the 5500 XSC or 5500XSB (ideally the XSB CI4 version with forged main gear, not the cast white metal of the XSC) for my 11' own surf rod.
OTGman
Before I forget, something those casters that help developed the rod told me.
The butt has a powerpoint for the gear box design to work. Generally it is around 2/3 rod butt length, where your right arm should be. This also means if you were to use KW40, it MUST be at the same position as the KW30 based on factory specs.
OTGman
I think you have to mail the Shimano rep to know. What I know is the larger models 10000 n above is parallel.
Tackle-holic
Hmmmm I think this forum has members that know more about Big Pit / Surf Spinning reels than Shimano rep does when it comes to THAT sort of information...
They will sell on number of bearings, X-Ship and slow oscillation. I doubt they will have any clue as to what we are referring to or why it is important.
What do you think Shimano's reasoning behind the zero degree shaft is? Cant see how it helps performance myself, but am happy to learn.
subaruseun
Best wishes
thanks OTGman.
i specifically requested a response with regards to the Kompressor S.
i have cast it with an ultegra 5500 xsb and penn fathom 25n, gives really good distance.
i want to pair it with shimano bullseye... is this advisable? this rod has plenty more backbone than my bm 60/50/430 ss.
