AYOBA! wrote:
Dankie, gaan sommer my drywer in die week daar verby stuur.
Contact Henkor for day old chicks
How to properly rig a fish head anyone?
With regards the day-olds - I put a cable tie through the eyes. Circle hook goes under the cable tie. I slice the belly open. Ive also used three chicks at the same time using this method - cable through each ones eyes and hook cable tied to the three ties.
7/0 hook
cast near the bank under trees.
40kg x 25m leader.
7/0 hook
40kg x 25m leader.
Thanx for your input. I like this rig. Simple, easy to make and it is not expensive. You also make use of a type of hair rig whereby the hook is totally exposed but to top it off you can modify it into a chicken bomb rig.
Only one problem I might see with it (chicken bomb). But first tell me when you use the bomb don't you get a lot off 'false' runs? What size Cats do you normally catch with the bomb? 3 kilo class? Maybe even a couple of foul hooks?
Excuse all the questions I'll explain later.
here was my rig that I posted for Day olds
http://sealine.co.za/view_topic.php?id=94043&forum_id=64
