Casting Distance
Hooked
Sylvester wrote:
Cast on a field and pace it out, always different over water though!
100% , grass is magnetic to lead and you always cast further over water cos the water doeasnt pull the lead down.I have noticed this phenomenon many times hehehehehehehe
Hooked
PS: Another great distance killer is a tape measure combined with grass.These two items together kill even more distance than you would think possible...( beach sand has a similair effect but its magnetic properties to lead are cancelled out by water )
gerritp
::S::S Baie snaaks.
misguide
:hyst::hyst:
Ziyz
:hyst::hyst::hyst::hyst::hyst:
ebs, get a line counter. The cheaper ones are not 100% accurate, but they give you a pretty good idea of your casting distance. Being able to actually measure your casting distance is a great motivational tool. You tend to practice a bit more.
I fish international competition in the freshwater, we are pegged in an area and have to determine form a distance how far competitors are fishing from the bank so we can get an idea of where the fish are.
We do this by simply counting, as fast as possible but without interval till their rig hits the water.  We then cast for the same amount of counts and then put the breaks on then our baits should be in the similar region to what theirs is.
We've taken it further by doing the casting thing on a field with a lazer range finder (tape will do fine) and coupling distances to counts.
I've got this well sorted and although not an exact science it gives a relatively accurate ability to judge the distance and based on my personal counts I have more or less this scale, yours might differ but once you've tested you'll know how far you or the guy next to you has actually cast.
For example counts = meters:
16 = 80m
18 = 100m
20 = 120m
23 = 145m
The more you practice the better it gets, in the competition arena I fish in knowing the distance is important as our fish are governed mre by thermoclynes than structure and fishing.
Strangely enough if you cast 1 oz or 8 oz the counts for the same distance are basically the same, give or take 5m.
Watch out for the magnets::S. Learn to count consistantly and don't count in 2's over the water and your distances over water will be similar to those over land.
Moby Dick
Hi
I google earth and use the measuring tape icon at the top.
Choose a landmark and I have very good idea of the distance.
Hope this helps.
Def-e-nition
16 = 80m
18 = 100m
20 = 120m
23 = 145m
how do the counts work ??
Walt
ebs wrote:
How does one determine what one's casting distance is?
To get an idea,I count the number of turns I crank on my reel.
On My Saltist 30H,it's about 0,91 metres per crank handle turn,but i round it off to 0,9m.So,say I cast and crank in 120 turns, I've thrown 108 meters.
It's not exactly spot on,but at least you get an indication of distance thrown at the beach.But,each day is different depending on wind direction and wind velocity.
Think if I remember rightly,Torium 30 which you seem to have under equipment used,and if reel is full of line,each crank handle turn is equal to 1,2metres.
Just confirm this as it may be in your Reel box in the reel specs.Otherwise check on Sealine threads as i did come across it somewhere at some stage.Cheers!
With regards the counting.  It is very accurate and once practised and confirmed on a casting range is very helpful.
Start counting as the weight is released and end it when the weight hits the water.
To determine what the count equals in distance cast on a field, count with rythm and as fast as possible lets say you get to 18, measure the distance where you weight fell from where you cast from, it should be close to 100m.
Verify this by doing 10 or 20 casts.  Get a buddy to go with you and let him cast and count and verify the distance versus the count.
You will find that your specific count gets you within 10m every time and will help you to determine distances cast.
In competition it's not how far your opponent is casting to get to where the fish are but that if you are in a similar area and you cast with the same count = the same distance = getting your bait where the fish are, whether it be a Gully, close to a reef or onto a sandbank.
ebs
appreciated guys, but i must say it sounds like a mission but a fishermans got to do what a fishermans got to do....
turboguppy
thats really a bad way of counting as the amount of line that is already on the spool increases with each turn.
for example with every crank the line wound on per crank is more then the previous because the spool diameter is increasing as the line fillsup the reel.
for eg ur 1st crank may be 0.90 and second crank line has to cover 1st cranks line so it will nw be 0.91.
hard to explain but think about it
Bryan
Walt
Bryan
Hi Brian!What you're trying to explain is that the revolutions alter depending on spool capacity at cast and then at retrieve.
What i've done previously when buying my Saltist is to measure my casting initially on a rugby field,and with my reel always full,the distance as to cranking turns was almost spot on.
This works for me,as I need to know at the beach what i'm throwing to ascertain that my reel is functioning to its full potential,and not in need of servicing/lub.And it's a proven fact that throwing on land is not the same as at the beach owing to sea breezes,etc.It's very different at the beaches.
Also,I read somewhere on one of the sites the problem with measuring casting with odometer attached to reel,is that it's not a true reflection as the arc in the throw forms part of the end result.So how does one measure true distance at the water's edge?
But,each to their own,and my method offers me an indication of my throw where it matters most,at the water's edge.Cheers!
Homie
Enigma,
That sounds VERY interesting....
Excellent idea for when you want to cast the similar distance to someone else, specially if you look at the spool when casting !
Expat
Mangi wrote:
A line counter for me is the most "accurate".
A line counter cant be accurate because nylon stretches because of drag in the water or  land...  Handel turns will differ from a full spool to an empty spool.
Anchorman
Something I do is to cast on the beach and then slowly walk towards the sinker while reeling in slowly, just to reel in the slack and then I count the amount of strides towards the sinker, the strides should close to a meter, otherwise you can go and measure your stride length at home and calculate the distance.
