100% , grass is magnetic to lead and you always cast further over water cos the water doeasnt pull the lead down.I have noticed this phenomenon many times heheheheheheheCast on a field and pace it out, always different over water though!
PS: Another great distance killer is a tape measure combined with grass.These two items together kill even more distance than you would think possible...( beach sand has a similair effect but its magnetic properties to lead are cancelled out by water )Sylvester wrote:100% , grass is magnetic to lead and you always cast further over water cos the water doeasnt pull the lead down.I have noticed this phenomenon many times heheheheheheheCast on a field and pace it out, always different over water though!
Hooked wrote:PS: Another great distance killer is a tape measure combined with grass.These two items together kill even more distance than you would think possible...( beach sand has a similair effect but its magnetic properties to lead are cancelled out by water )Sylvester wrote:100% , grass is magnetic to lead and you always cast further over water cos the water doeasnt pull the lead down.I have noticed this phenomenon many times heheheheheheheCast on a field and pace it out, always different over water though!
Baie snaaks.Hooked wrote:PS: Another great distance killer is a tape measure combined with grass.These two items together kill even more distance than you would think possible...( beach sand has a similair effect but its magnetic properties to lead are cancelled out by water )Sylvester wrote:100% , grass is magnetic to lead and you always cast further over water cos the water doeasnt pull the lead down.I have noticed this phenomenon many times heheheheheheheCast on a field and pace it out, always different over water though!
. Learn to count consistantly and don't count in 2's over the water and your distances over water will be similar to those over land.I fish international competition in the freshwater, we are pegged in an area and have to determine form a distance how far competitors are fishing from the bank so we can get an idea of where the fish are.
We do this by simply counting, as fast as possible but without interval till their rig hits the water. We then cast for the same amount of counts and then put the breaks on then our baits should be in the similar region to what theirs is.
We've taken it further by doing the casting thing on a field with a lazer range finder (tape will do fine) and coupling distances to counts.
I've got this well sorted and although not an exact science it gives a relatively accurate ability to judge the distance and based on my personal counts I have more or less this scale, yours might differ but once you've tested you'll know how far you or the guy next to you has actually cast.
For example counts = meters:
16 = 80m
18 = 100m
20 = 120m
23 = 145m
The more you practice the better it gets, in the competition arena I fish in knowing the distance is important as our fish are governed mre by thermoclynes than structure and fishing.
Strangely enough if you cast 1 oz or 8 oz the counts for the same distance are basically the same, give or take 5m.
Watch out for the magnets. Learn to count consistantly and don't count in 2's over the water and your distances over water will be similar to those over land.
How does one determine what one's casting distance is?
ebs wrote:How does one determine what one's casting distance is?
To get an idea,I count the number of turns I crank on my reel.
On My Saltist 30H,it's about 0,91 metres per crank handle turn,but i round it off to 0,9m.So,say I cast and crank in 120 turns, I've thrown 108 meters.
It's not exactly spot on,but at least you get an indication of distance thrown at the beach.But,each day is different depending on wind direction and wind velocity.
Think if I remember rightly,Torium 30 which you seem to have under equipment used,and if reel is full of line,each crank handle turn is equal to 1,2metres.
Just confirm this as it may be in your Reel box in the reel specs.Otherwise check on Sealine threads as i did come across it somewhere at some stage.Cheers! Â
thats really a bad way of counting as the amount of line that is already on the spool increases with each turn.
for example with every crank the line wound on per crank is more then the previous because the spool diameter is increasing as the line fillsup the reel.
for eg ur 1st crank may be 0.90 and second crank line has to cover 1st cranks line so it will nw be 0.91.
hard to explain but think about it
Bryan
A line counter cant be accurate because nylon stretches because of drag in the water or land... Handel turns will differ from a full spool to an empty spool.A line counter for me is the most "accurate".
