the best fixed spool reels for braid fishing are ones with a very defined cross weave line lay as the braid is harder to be pulled into itself when heavy loads are imposed on it , I have seen some big game fixed spool reels that fall into that category , but the downside is that they are very expensive . the plus side is that they will lastremember if you gonna put on braid it must be wound on very tight.. as tight as you can wind it on or perhaps someone at a tackle store, this will help that braid does not cut into itself and you end up with a birds nest or something similar..
