Cannon Bionic Finger
BluFlu
Wow - 250 yards - half of that and I will be chuffed as nuts - thanks for the great feedback - will definitely keep the loop bending bit at the back of my mind if I encounter any issues.
purglaspete
flippy wrote:
remember if you gonna put on braid it must be wound on very tight.. as tight as you can wind it on or perhaps someone at a tackle store, this will help that braid does not cut into itself and you end up with a birds nest or something similar..
the best fixed spool  reels for braid fishing are ones with a very defined cross weave line lay as the braid is harder to be pulled into itself when heavy loads are imposed on it , I have seen some big game fixed spool reels that fall into that category , but the downside is that  they are very expensive  . the plus side is that they will last
purglaspete
its an accuriste I think  , the braid that I like to use for top water fishing  is the open weave type that floats it is very soft and limp and for the bottom fishing I prefer the coated type
BluFlu
Went out today and had a few throws.
At the outset must say that 'finger' vs 'no finger' no contest - 'finger' tried both and the finger allows you to really put your arms into it. Was not loading the rod but getting 75 to 80 metres each throw.
Thanks to purglass for his tip - positioning of the finger is NB in that it must be over the reel seat pretty much.
If you are putting out heavy baits 3 ounce plus there is no choice.
angler 1
Guys i see some dudes put on a heavier leader, the braided type in the front of the braid in my case 50lb HMP and 150lb leader , what knots d you use and does this not decrease ditance?
i tried the bob sands knot but it takes a beating through the guides and makes a racket and yes i made a proper knot with it!
angler 1
P.S i am using a saragossa 18000 and a 12' shimano tirelago for throwing medium size baits
If it's a 150lbs nylon leader then not Bob Sands for casting but a PR knot
If it's a braided leader then either the spyker knot of the bob sands. It is smaller than a bimini and gives better breaking strain than the Spyker.
When making a Bob Sands knot for braid to braid then only use 6 turns up and 3 turns down as the mechanics of the knot on braid to braid are different from Braid to Nylon
This pic is of a 150lbs Jerry Brown leader to 50lbs with a #12 guide that is the usual smaller guide on a rod for ed's
BluFlu
Seeing that there has been some activity onmy original post and having reread it perhaps some feedback is called for.
1. I have actually bought an Accurate SR20 - seems it was love at first sight:)
2. On the finger side, did try it with the original setup. Worked well but I found that in the heat of close combat tail hunting it simply took too much time to setup. That and given the weights I am using does allow me to use bear fingers with impunity, relegated it to the cupboard and then to a fellow sealiner who I hope has enjoyed it.
I will however unreservedly recommend that as Enigma said that with heavy sinkers that it is a must! Really allows you to load the rod with a very precise disengage.
There duty done:)
angler 1
lol guys after reading this i now own a bionic finger purchased this afternoon and taking her for a spin tonight for a few cows hopefullyy , thanks with the knots Craig!
angler 1
Craig one question 50lb to 150 lb is it really necessary to make a double line from the 50 lb or tie it straight on ?
angler 1
took the bionic finger for a spi , but i have a problem , my tirelago rod reel seat isn the way of a proper position the reel seat moves for casting then can be lowered like a normal rod , i need some way of tempararly fiing the finger then removing , any tips otherwise its tw cable ties after every cast aaaarrggghhh!!!
angler 1
i really want to keep the bionic finger but if i cant mount it in suvh a way that i can release it during fishing i have a problem , now to investigate my options of mounting it on a clamp or something similair!
