Cannon Bionic Finger
BluFlu
Was wondering if anyone has used the bionic finger for spinning. I am particulary interested in the following:
  • Has it improved your distance and if so how much?[/*]
  • Is the clipping of the line into the finger an issue and take time - which obviously one can ill afford when the fish are boiling?
Look forward to you responses!
Here are a few pictures of the Canno Bionic finger.
Pic 1:
spirits
 [/i]
this is attached to the Assassin Beach master the new ones for R 1500....it is not that new but I think it is the one above the standard Assassin beach master[/i]
BluFlu
I got mine at my second home at Suburban Spare when i relented and got a spinning rig for tail. Quite pricy but Johan swears it add 50 metres as you can give the cast everything!
BluFlu
They are around R250 if I remember correctly - my eyes were closed when I handed over the card yesterday:)
The one advatage is that you can tie a traditional 2 or 3 metre leader and actually cast the braid from the reel directly as opposed to tying a londer leader that extends onto the spool. The reduction in drag will probably help somewhat for distance and would definitely avoid our friend aboves problem:)
Slimshady
Hi BluFlu
Let us know what the outcome of the casting distances is , if it helped or not. I've got a coffee and trying to get some more distance.
BluFlu
Will do 'shady.
Read a few reviews on stripersonline.com and learnt a thing or two, apparently:
1. Fishing with mono onto you spool causes wind knots.
2. When actually holding the braid with your finger and using slightly heavier lures one needs to really tighten up your drag to avoid the braid slipping and cutting you.
3. Distance is improved due to - reduction in fear of cutting yourself and hence really giving the cast gas - and not having to deal with finger fatigue from repetitive casting.
Not endorsing the views above as I have yet got no experience with the goodie but they seem to make sense, especially with heavier bait/lures.
Slimshady
I have been using insulation tape on my finger/s so it kind of slides off the finger easier and doesn't cut but i still need more distance. Only getting about 70m to 80m with a 5oz and bait (eg. chokka/sardine combo). Equipment as you can see is fairly cheap. I'm still a novice so need to practice.
BluFlu
Your equipment point reminds me of something.
At a flyfihing exhibition, a master flyfiherman (and I know a few) cast an entire flyline out (30 yards) with a broomstik with a hook eye you use at home.
I still struggle (not that I practice fly fishing much mind you:)) to get a decent 15 to 20 metres with my 9 weight!
Point is if you become a master the addition of fine tackle as the finance allow it merely adds to your art. Putting lipstick on a bulldog leaves you with well a bulldog:) Actually that pretty much describes me :?
I will give the rod a few throws this weekend using both the finger and not (with gloves on of course) and give you a low down on Monday.
Theory says it should work but lets see - the proof is in the pudding:)
Must-Byte
I have one on my spinning rig. It definately helps distance wise it also makes it much easier if you throw a heavier bait. After using one I wouldnt think of not having one
BluFlu
Cheers thanks for the feedback - I cannot wait to weild my new outfit in anger.
BTW it is a Berkley Air XH with A Saragosa 8000 with 50lbs braid.
I've built a lot of them onto saltwater rods set up for Grinder fishing.
The agents for them are Basil Manning and you can buy them online from BM for R200
http://www.basilmanning.co.za/index.php?option=com_virtuemart&page=shop.product_details&flypage=shop.flypage&category_id=168&product_id=2604&Itemid=29
They do work excellently and it takes very little time to hook the line/braid in for the cast.
Getting the timing right is key and it allows you to really, really REALLY load a rod.
It makes casting an 8oz with a bait on a grinder a reality and once you get the timing right you can really get good distance because you can load the rod perfectly with it.
i use mine for casting big weights and nailing the cast, as for standard braid sport Elastoplast remove the hazard of braid casting but still keeps sensitivity
flippy
remember if you gonna put on braid it must be wound on very tight.. as tight as you can wind it on or perhaps someone at a tackle store, this will help that braid does not cut into itself and you end up with a birds nest or something similar..
neilg
Plaster, glove, deep sea "vinger lappie", they will all do the job
Thinner braid will cut you
Still think the bionic finger is a gimmick, but u never know, I might be wrong
purglaspete
I have been using the cannon for quite a few years now and they are good but I found to get the best out of them you need to modify the hoop , what I did with mine is pull the hoop out of its two holding tubes and put the hoop in a vice and bend it so that when it is in the ready to cast posiotion it goes further over the capstan , the reason for this is that when I have been tournament casting with it just the slightest ease in pressure and the cast goes away I also like to put a couple of turns around the capstan with the leader it takes some of the strain off the clutch on the reel . I have cast over 250yards with the cannon . it is also good with heavy weights
