Can someone I.d this shark
Dorado75
Caught this shark out here yesterday, 120 miles off the coast (Angola) in around 1400m of water.
Hi Donavan. I have two guides open in front of me and the closest resemblance I can find is the soupfin shark, although they say the soupfin occurs in 100m depths....so I don't know so much.
What is interesting is that your shark appears to have only 5 gills?
Some serious clutch-cable you're using there boet! lol
Dorado75
Hi Chris
Jeez you are observant, i did not even notice that!
That is def no soupfin shark, seen plenty of those in my day, and we are a tad over 100m, the shark was however caught right on the surface.
We dont have any tackle shops out here so we have to improvise on the tackle, the cable seems to do the job!
@Glenn- caught right on the surface, from a workboat on the oilfields
Big Gray
Howzit Don,
Nice shark, which boat are you on and what is your approximate position?
It's as hotazel here in Glencairn and it's navy day. We've seen some great areonautical displays. Formation flying by the Pilatus pilots is awesome.
Anyways, I'm off to ssssshhhhhh you know where and just for the hell of it, am going to slide a yellowtail head. I haven't even caught a hottie for weeks.
Cheers,
Brian.
Glenn
@ Dorado75
When you say surface.. how deep?? What bait did you use? Nice colour'd shark! Is it around 25-30kg or something..
Dorado75
Hi Brian, cant be too pleasant to be in Simonstown today with all those people in that heat.....
I am in Block 17 and workingoff one of Total FPSO's here.
All the best with that slide, there are some big ones swimming around that side! Let us know how it goes!
Dorado75
Glenn wrote:
@ Dorado75
how deep, about 20cm under the surface, watched the bugger grab the bait, tried to pull it away from the shark but it was a bit too quick, for bait i was using a piece of big eye tuna. Size, it was around 5kg, a very strong 5kg though!
Glenn
@ Dorado75
Hard to tell in a photo how many KG Shark was.. :lol:1 I think one was a tad over! :hyst:
I've never used hand line before.. What does it feel like when pulling a big fish in.. It does the job quicker I would presume ?
The stuff you pull out on handline truly amazes me Donavan....flip, I don't know if I'd have the guts for it! You lost anymore fingers lately? lol
Dorado75
The stuff you pull out on handline truly amazes me Donavin....flip, I don't know if I'd have the guts for it! You lost anymore fingers lately? lol
If i could use a rod out here i would, but handline fishing for me can be just as much fun as on a rod, pulling a 35kg Dorado or 50kg Tuna on a handline takes just as much skill as on a rod and reel i recon!
As for losing anymore fingers, still only minus that same 1/4 finger, but i had a run in with a Hammerhead a few weeks ago in false bay, the bugger was quicker than me and managed to grab my forearm, all i needed was a few stitches and lost a bit of blood!
@Whaler- i am busy searching the net for this shark, one of my marine biologist friends has said that it has to be in the Carcharhinus family as per the teeth!
Dorado75
Whaler wrote:
Looks like a spinner? longnose johnson shark? maby the Egheads can confirm? Reefs, Aqua?
I just did some searches on the spinner shark and it does look similar, but the spinner appears to have a longer pointier snout than this shark, and they also say that they are found closer to reefs and shallower waters
Eish...you're the real deal if ever i've met one boet. Flipping hardcore fisherman!!!! ::respekt:::respekt:::respekt:
Dorado75
More accident prone than anything Chris, and fishing almost every second day of the year at home and and work increases the risk!
@Sailfish- checked out the milkshark and the color looks different and according to their habitat they stay close inshore, the teeth are apparently a lot more rounded
Bit wayward for a spinner. Southernmost extremities for spinners extend to just below PE on the East coast and they are seldom found in water deeper than 75m
