Being prepared!
damian27
im also wanting to make (or buy) saddle bags as wellone for each side and maybe the front of the box. not to sure just yet.
@ Twitch - i like your idea, was thinking about doing something similar. i Saw another guys one on the weekend. not to sure how his is done as i was just walking past. also with the sun damaging your line, he had something on his rolls of leader(looked like girls garters or something like that), covering them from the sun and aslo so they do not unravel. you could even use those Jarvis walker rod straps like Boepens has on his rod holders to roll around your spools of leader.
im also wanting to put a trace pouch in the lid of the black box.
mikesfb
or just buy perlon leader line, it comes with those cool plastic covers that stop the line unravelling and stop the line getting sun damage. i think its perlon.
Kosi Fisher
Or just get yourself a rubber band (rekkie / elastic), wrap the end of the leader once or twice around it and put it over the spool. That way, it'll also retain tension on the spooled leader when you take some off...
flippy
howzit kf.. myself use a trick where you tie a cable tie round the spool but with a small hole in the cable and pull line through the cable tie so ensuring no line wraps etc..heres a pic
and some nice ideas here fellas..keep em' comin._seal1_
Kosi Fisher
Yup, that works too, but the elastic is reusable and doesn't have to keep being tightened like the cable tie.
Would rather use the cable tie to keep my YT head on the bronzie circle hook...  :)
boepens
Hehehe now u remind me of my playa days
Think I got seven if the vrou aint burned them ,jirr I had a knack for them
:fbash:fbash:fbash:fbash
Tw1tch
I have 50mm velcro which i wrap round the spools to prevent sun damage, they are used to wrap my rods when im walking. Ive got 100, 50 & 25mm so will make for each spool. Guys please post any pics of custon saddle bags you may have or any other ideas on custom boxes.
damian27
was at a tackle shop now at lunch time and they have some saddle bags there, most of them are small (the ones for you fishing bucket). i found one good size one, i must jusr figure out what i could use it for. its big and seems splash proof, it has velcro right around, but the inside has compartments.
Twitch I'm sure you've seen the inside of mickeyg's box.
I like that idea. The way he stores his grapnels inside the pvc pipes. Has like 10 cm pieces of pvc attached to the inside of the box. And he bends the wires in of the grapnells and push them into the pvc. Sits leka secured
Maasbanker
So, if that's the outside of your box, what do you put inside? This is how mine looks...
Tw1tch
@Mike - cheap to do and easy to make yourself.
@US - Yeah i like to idea for grapnels but im using the one's from the TD and they wont fit in there. I reckon one side of the saddle bags for sinkers and the other for food should be perfect. The utility tray is an idea i want to try.
