Assassin Beachmaster
DWB
Hi D75, i've spoken to purglas about their 3piece rods. They strongly feel that its not in the same class as their 1piece rods..... They wouldn't even sell me a 400/6 3piece coz they knew i have the 1 piece already....
Their 2pc rods aren't bad at all
carcharias
Ive never seen a 400 in three piece. Get a two piece if you can transport it. The more pieces to a rod the less feel it has. Multi piece also effects how the rod will load.
My 2c.
YzeOne
Basil Manning @  Gateway DBN offered me a 400/3 in a three piece - it was called a Purglas Executive. I was going to take it however the old fishing folk on whose experience I draw heavily said that it would never match the smoothness / casting action of a one piece so I go the one piece.
Dorado75
I managed to track down a 3 piece stoke 2 and got it yesterday for a excellent price!! I have no had the chance to try it out yet, but it prob wont be as nice as the 1 piece as it is slightly heavier, but even then it should be a excellent rod!! Going up to Namibia in a week or so, should be able to put it to the test then!!
riekert
Firstly, I use graphite drag washer grease (sold by Kingfisher) on the inside of my Assassin Beachmaster rod sections as lubricant. A very thin layer applied with a cotton bud to the insides will last for a couple of outings and makes disassembly of the rod a piece of cake.
Secondly I always use two rods when fishing: a Purglass 400/2 one piece and the Assassin beachmaster (either with medium or heavy tip). I find the Purglass 400/2 is a far superior casting rod than the beachmaster with medium tip. However, for me, the beachmaster with heavy tip definetely cast further than the Purglass 400/2. I have a sneaky feeling that heavier Purglass one piece rods (400/3 or 400/4) will outcast the Assassin beachmaster with heavy tip. I think it all lies in the superior action (capacity to load the rod during the cast) of a one-piece rod.
willo
once u do get it apart,make a small hole in the rubber at the bottom of the male section - this helps prevent the vacume caused by heat and sealed by salt/dirt wich causes the pieces to stick ... my 2c
Johno
Thanks for all the advice - I have tried everything as per the booklet from assassin except the face oil trick - will try that when I get home later
Rusty
HI GUYS CONTACT BASIL MANNING ON 031 2632372 AND THEY WILL SOLVE ALL THOSE PROBLEMS ,CONTACT PERSON TO SPEEK TO IS BARRY WAREHAME.TIGHT LINES RUSTY.
Simen
2 guys standing back to back- place the rod ( horizontal )so that 1 guy grips below the joint and the other above.--Take a firm grip and push with your backs againts each other. This stops you from pulling each other all over the place and you can apply max preassure. Once the rod is loose check that tha rubber plug ( some rods )which is in one section ( male ) is not to large . If it does not slide in easily trim the rubber with a piece of fine sand paper ( 1000 grid ). Should that be okay and the joint is still very stiff use the same sand paper and work 80% of the joint down a bit, that leaves you with 20% for a very tight fit and you only have to fight with that 20% when taking the rod apart.
