Assassin Beachmaster
Johno
Can someone please help  - I am having great difficulty taking my Assassin Beachmaster 3 piece apart after fishing  - right now the middle piece and the bottom piece is so tight I cannot get them apart  - tried brute strength, ice and heating it with a hair dryer!
habib
heres sumtin that worked once for me....dunno if i will make sense to u tho.....u will need 2 ppl to do this
place the butt of the rod on the ground with the rod been vertical with the mid section facing up to the sky....
while 1 guy holds the butt section tyt tyt tyt....the second guy grabs the mid section and vigourously shakes it and at the same tym pullin up.....it will slowly .....mm by mm work itself loose
u see wat i mean??......dus it make sense bhai?
Dorado75
Other than the hassle of getting the rod apart..... how do you rate the Assasin? I bought one a week ago and still waiting to try it out!
Hooked
Take two pieces of rubber and wrap a piece around each section.Twist and pull apart at the same time.It helps if you have someone else pull one section.Do not lubricate the joints with anything.A tight fit is better than a loose fit.
Nick
For now you probably going to need two ppl toget it apart. And just pull and twist.
Once you get it apart, take a candle and rub the wax along the "male" part of the rod that slides into the lower section of the rod. I also use to battle with getting it apart but havnt had too much trouble since doing this.
carcharias
This sounds crasy , but works perfectly. Rub some of the oil from your face onto the join, the rod will come apart easily. Ask Deon ,Skrops,Kalahari and Habib, Ive shown them all this trick and it works.
On_Dad
@ @Johno- :welcomesea:
Once you have the joints apart, wipe down with a solution of warm water and dishwashing liquid. Wipe dry and apply a little Mr. Min
It prevents the salt build-up that normally worsens the tightness
deisel
i hate those rods i got two before i learnt my lesson, they rust aswell, even if you rinse them and treat them right
POSTHUD
For fly rods, you can put the rod on the ground behind your feet, now bend down and pick it up with both hands and place them alongside your knees, staying in a half squatted position with the rod behind your legs, start to force your hands away from each other by using the power of your legs. This is the safest way to seperate the pieces. This will probably work for the bigger rods as well.
Also, I agree with carcharias, there's no better lubicaton for your rods than the oil from your face. I usually rub the male pieces of the ferrule along the side of my nose.
lushwill
i have the same problem with mine, i love the rod though. i fell with my rob in hand and broke my medium tip. is it worth it buying a new tip? where and how much? thanks guys
Durran
Contact Basil Manning directly...they in Durbs and can find them online.
Well worth buying a new tip, the medium is an awesome rod!
Dorado75
I used my Beach master for the first time this morning, its a nice rod but i have top say that it does not cast as nice as my Purglas 400/2
