jonno_jonno_999 wrote:
Masking tape goes on top to prevent the bolt head and washer bonding to the epoxy that might ooze through the holes and also leaves the surface clean for fitting the final part. I suppose once you've done this a few times you may not find it neccessary. One important fact I may have missed is that the bolts should have some PVA release agent on the threads if you intend leaving them in overnight. jonno this whole thing sounds like a mission but it's actually quite simple. The camera I normally use is not here but if you want I'll post step by step pics as soon as I get it back if you want.Maybe I'm a bit thick but (a) does the masking tape go on top or inside and (b) y is it necessary?
