Aluminium beach cart
Reef Raggie
wollychop
From a US kayaking site - a homebuilt design that uses 50mm PVC piping as the framework in its construction. Sounds like the right material to use: Cheap, easy to work with, corrosion proof, light. Aluminium is great, but the standard grades available in the local hardware store corrode and are extremely expensive. Also, welding might be necessary - and ali welding expensive.
BRENDON
What about the kids toys. they have those little trolley type things. i am sure with a little inginuity one can make it work for a fishing trolley
Mel G
Howzit guys talking about trolleys, i saw a great 1 at Game, its a gardening trolley, and it was marked at R799, it has 4 inflatable wheels, and it looks like it can carry a monster load...It also has drop down sides. The only thing is that i dont think it is collapsable...It is also galvanised, so no rust...
MickJack
If you had a power-kite buggy, you could adapt it by replacing the front wheel with  handles or shoulder harness
wollychop
That sounds like a bad thing!:p WTF does it mean? I was suggesting one could modify the idea to suit the application.
No, just kidding... traagseun means S..L..O...W boy. ::H
We were all waiting in anticipation for the web addr for that kayak site, which you e....v....entually got for us!! Thanks a mill. Its a good one!
Riymos
Banned
Guy's
I seriously think you need to give BM a call.In my opinion the wheel thingy they have is the best all round package.It is sort of like the bouys you use on a boat.The advantage is how light and easy it is to carry.
The last thing you want is a huge monstrosity that you have to lug around with you in a 4x4.Just my opinion.What i will do is hopefully get them to send me a pic of it and post for the guy's...
Cheers Riymos
Chris1
Hi Rooken
Yes I will have 1 any day know. I'v designed 1 for my owen use. Its made of Alli. and is about 1m ling x 600 mm wide and 250 deep. Once it's done, I'll  put a pic on so you can have a look. That should happen in the next month, end of June.
Chris
Rooken
Hi Chris
Thanks very much. Ive finished the proto type and tested it last week. I found the c of g was out and needs to be changed as it required a lot more effort to pull (too much foreward c of g). I put a crossbar which you step inside to pull which doesnt work so Im going to rig a belt or harness of some sort. The wheels which I thought were ok also battled in the soft sand but one of the guys posted an adress in the USA which looks like the right thing so Im going to order 2 of them. Im pretty ignorant with computers but as soon as I can get someone to show me how I will send a photo. Im sure it will assist in your design
Rooken
Captain Jack
