210lbs bleeding wire bitten/clipped off behind the second hook..?
ants
I don't want to hijack the other thread on "steel" and therefore this thread.
On two occasions it has hapenned to me before that I reel my line in to rebait on a slide set up where my 210 lbs bleeding wire trace got nipped off without the slighteswt indication of a bite/pull/nibble or anything..? The trace is just minus both hooks and about another 30 cm of steel.
This happened once at Macasser and once at Tugela whilst fishing for sharks. It happened to my friend as well on KZN south coast recently. Are there crabs or something that can cut through this wire..? WTF..?
tuna
i have been cut 3 times on wire that diam, specially when you hook it right, thats why i like my 300lb and 440
Bleeding wire is still more than enough for most sharks
Trophy
Hiya Ants,
You got me...at least on the East Coast you get a decent pull beofre all goes pop!
Seems you attract the sneaky fellas where you fish. LoL
I don't think many crabs will easily snip 210Lbs steel?
JJ Pienaar
This must surely be the weardes thing i ever heard Fishing wize... Are u sure the spear fishermen arnt playing around with u ou's cuting your bite trace with sidecutter's ha ha ha.,
Nemesis
Its not the Knots,i know what you mean Ants,the same thing has happened to me on various of occations and not only with Bleeding wire,the only suspects that come to mind are big Blackfins,Greys and Zambezies.Strange thou,the drag doesnt even go,nor does the rod bounce!
Stroker
Not so weird guys, with the plastic (red, black or clear) coating on the steel the sharks teeth will grip on the wire on one point and then the abrasion of the fight will be concentrated on that small piece, hence it gets "bitten through" much easier. What I do is to strip the coating of the slide or throw trace and you'll find this will not happen as readily, as the teeth cannot grip on one specific region. Also have found that should the wire have a kink in it it will snap there on prolonged tension. just my 2c's
alchar
Could be Big Moray eels, were you fishing reef structure, happened to me before where i actually wound in my line which felt very heavy and out came a fairly large eel which had gotten entangled in my 200lb steel trace. On untangling the eel i found the wire in 3 places virtually bitten through only holding by the carbon coating.
Pucky
I Agree with Nemisis. A mate of mine swam a 10 kilo Diamond at Tugela. With out any bump or rod bounce his line goes totslly slack.... reels in only to find that about 3m of his 250lbs swim trace has been bitten off.
I think it all depends on the angle in which the shark comes in to pick up the bait, even slide baits.
steve m
my guess a big sharpnose bronzie if it can do this to a seal imagin 210 steel!
ANTS.
Ok I dont want to sound stupid or anything this is just a thought.
If you say youre steel trace was bitten off without you even feeling the take it can not be a shark impossible on steel ,you will have a pull at least.
How ever fishing from a boat I caught some Puffer fish on spoons pulling them just below the surface ,funny thing is that 2 of them actually bit right through my 6/0 hook without me realizing it I thought it was on and then came off.After inspection I saw that the hook was cut in half. we where sight casting for them wihile going for TARPON.
So if they can be in the area that you are casting youre bait they will definetly cut through a steel trace as the diameter is very low and will easily fit in it's mouth
My 2c anyway
Kumz
I do the same Stroker !!!
Nemesis.
No it cant ,but becuase it is eating youre bait ,it might be that the steel comes into it's mouth ,and it wil bite it off,without you even feeling a little tug.
these things have got some serious dentures and will cut through steel easily.
Spoke to Carlos and told him about this thread the first thing he said was" PUFFER FISH."
Remember if it is anything big you will get a pull first there is no way a shark can bite through youre steel without you getting a pull or a strong tugg.
