210lbs bleeding wire bitten/clipped off behind the second hook..?
khan
ants wrote:
I don't want to hijack the other thread on "steel" and therefore this thread.
On two occasions it has hapenned to me before that I reel my line in to rebait on a slide set up where my 210 lbs bleeding wire trace got nipped off without the slighteswt indication of a bite/pull/nibble or anything..? The trace is just minus both hooks and about another 30 cm of steel.
This happened once at Macasser and once at Tugela whilst fishing for sharks. It happened to my friend as well on KZN south coast recently. Are there crabs or something that can cut through this wire..? WTF..?
Ants
the puffer bite off is a serious contender, but how many of them would be on the shore line where you put out your bait??
Deepsea fishing yes maybe!!
I fish at Umkomaas a lot and have on numerous occasions lost my trace in this way, i believe that it is small greys as they often bite off wires given their small razor teeth and the way that it sits in their mouths, as Nemesis has mentioned they also come in after a take and you often find your line slack when you pick it up off the pension pipe only to find a small grey along the shore break.
Guys i dont put off any possibilities but looking at where you were fishing, i would say greys!!!
willo
might be slightly off , but that looks like these north-west blowie/silver pufferfish (lagocephalus sceleratus) they can reach a length of nearly a meter and have been known to attack divers ..... and are capable of biting through hooks and human bones - watch those fingers !
tuna
die vis wat julle van praat is nie n algemene vangs nie, ek dink dis meer haaie wat onder jou inswem en jou staal afbyt
KLIPVIS
Anthony soos jy kan sien is hier groot goggas wat uitkom , dink daai besigheids trip moet vervroeg word , hier is baie werk en die kliente is nie happy nie.
KLIPVIS
SO VER WAT EK VAN WEET 107 , 114 , 130 , 149 , 171 KG en die weer was nog nie eers reg nie , die goed by sommer in die plat skoon water gister.Ek werk ongelukig , die weer die naweek is sleg , maar die SO begin waai sondag , volgende naweek is daar chaos.
Dit is nie ON DAD nie , maar liewer FFS DADDY HELP ME !
Weedeater
Spyker Kruger wrote:
Nemesis.
No it cant ,but becuase it is eating youre bait ,it might be that the steel comes into it's mouth ,and it wil bite it off,without you even feeling a little tug.
these things have got some serious dentures and will cut through steel easily.
Spoke to Carlos and told him about this thread the first thing he said was" PUFFER FISH."
Remember if it is anything big you will get a pull first there is no way a shark can bite through youre steel without you getting a pull or a strong tugg.
Puffer biting through 200lb steel wire? Bloody hell!!! :shock:
