0.80 WINDON
SUNSHINE
Hi guys.
I have recently purchased a Penn Battle 6000, loaded it with 300m 20lbs Jerry Brown braid and 100 m 50lbs backing.::S
I am looking for 0.80 Windon leaders to use with it, can anybody let me know where I can get them?^^..
eviltoy
Why not make them? They quite easy to do. One thing though the windons tend to pop off a spinning reel when not in use quite a bit
SUNSHINE
Reel feels and looks solid, just wanna go test it.
Neilg has been using one and says it BRILLIANT.
Will have to see if I can make one, would be easier to buy for now till I know what Im doing.
Mango
why do you want to go with Nylon for casting and to save the finger
I got some 120 pound JB from Trophy and it works great as a casting leader used a spyker knott to connect but you gave me a good idea make a tanaka loop(small)in the heavy braid and a braid splice loop in your main line then you can use a cats paw
SUNSHINE
Hi Mango.
I will be using throw baits, how did you connect the 120lbs braid leader to the swivel?
How long is the braid leader, 9m?
I wanted to use the nylon leader for abrasion reasons, will the 120 lbs braid do the trick.
Mango
Sunshine i think braid is more abrasive resistance than we give it credit i tied in 120 pound to 30 pound using the spyker knot and it came out nice nice and slim
SUNSHINE
Do you attach your 120lbs braid leader to here. (yellow dot). This is the trace i will be using.
Mango
Jip That is the spot what I do to save on the braid leader is make a twin fig 8 knot eg make a loose one and then a second one that locks in place ontop off the first wet both and pull tight takes a bit off practise but works well
other otion is a small power swivel that fits the eyes and with a permanent connection think it is rated at 30 od KG with a 2 way snap between the 2 swivels
SUNSHINE
Morning guys.
Yesterday after work I tied my first in-ed trace, used some of Trophy’s knots on the steel. Trace came out great.
Then I started wondering about this whole leader thing.
Mango, your idea about the 120lbs braid leader was still stuck in my head, so I tied the trace directly to my  20lbs braid using a simple Palomar Knot.
Then hooked the whole lot onto my back gate at home, man was I surprised, I put MAJOR pressure on it and all held up great. Rod and reel combo with this braid is amazing, was really shocked at how much pressure I could put on it with no hassles.
All I need to do now is get hold of Trophy for some 120lbs Jerry Brown braid. Have sent him a PM and Left him a message on Facebook but the man is a ghost.
Daryl Norton[/b]
