Mike, Saligna makes a good wood and fairly easy to carve. The grain is very consistent. Inconsistent grains can bugger you around making it difficult. It is also a good idea to use pine dowels, you get them in quite big diameters. It is soft, easy to carve and sands easy. Once you are done, and you want to make a nice and strong or a hard shell, get some floor epoxy, dilute it heavily 4 to 1 with thinners and dip the lure in it for an hour. The wood will absorb the epoxy deep into the wood making it hard. You could also use a resin, dilute it with Acetone.
Any decent hardware should carry the downels. They also use those dowels for curtain rails.
