Winkelspruit
hrogers
Onbeplande visvang gedurende Jan 2023 by Winkel spruit
Spesies gevang :
Blacktail
Yellowfin bream ( Stmpnose)
Large spot pompano ( Wave Garrick )
Silver Sillago = 38.5 cm
Dusky shark +- 6 kg - Aas wat gebruik was, heel sardine
Shad - 51 cm
SPFOldTimer
Question to all the pro's out there !
What is the chances of catching whiting regularly anywhere on the KZN Coast ?
kitefisher
Classification / NamesCommon names | Synonyms | Catalog of Fishes(genus, species) | ITIS | CoL | WoRMS | Cloffa
Actinopteri (ray-finned fishes) > Eupercaria/misc (Various families in series Eupercaria) > Sillaginidae (Smelt-whitings)
Etymology: Sillago: From a locality in Australia .
More on author: Forsskål.
Environment: milieu / climate zone / depth range / distribution rangeEcology
Marine; brackish; reef-associated; amphidromous (Ref. 51243); depth range 0 - 60 m (Ref. 6205), usually 0 - 2 m (Ref. 90102). Tropical; 26°C - 29°C (Ref. 4959); 41°N - 36°S, 20°E - 166°E (Ref. 6205)
DistributionCountries | FAO areas | Ecosystems | Occurrences | Point map | Introductions | Faunafri
Indo-West Pacific: southern Red Sea (Ref. 94953) and Knysna, South Africa to Japan and south to Australia. Reported from New Caledonia (Ref. 9070). In Japan, this name has often been misapplied to Sillago japonica; often misidentified as Sillago lutea or Sillago vincenti.
Length at first maturity / Size / Weight / Age
Maturity: Lm 16.7, range 13 - 19.1 cm
Max length : 31.0 cm SL male/unsexed; (Ref. 44894); common length : 20.0 cm SL male/unsexed; (Ref. 9679); max. reported age: 7 years (Ref. 43081)
Short descriptionMorphology | Morphometrics
Dorsal spines (total): 11 - 13; Dorsal soft rays (total): 20-23; Anal spines: 2; Anal soft rays: 18 - 23. Swim bladder with two anterior and two posterior extensions. The anterior extensions extend forward and diverge to terminate on each side of the basioccipital above the auditory capsule. Two lateral extensions commence anteriorly, each sending a blind tubule anterolaterally and then extending along the abdominal wall below the investing peritoneum to just posterior of the duct-like process. Two posterior tapering extensions of the swim bladder project into the caudal region, one usually longer than the other. The species has a low lateral line with about 70 scales (Ref. 48635).
Biology Glossary
(e.g. epibenthic)
Common along beaches, sandbars, mangrove creeks and estuaries. Recorded from freshwater. Form schools. Adults bury themselves in the sand when disturbed (Ref. 6205, 44894). Feed mainly on polychaete worms, small prawns (Penaeus), shrimps and amphipods (Ref. 6226, 6227, 44894). Oviparous (Ref. 205). Larvae and juveniles are pelagic feeding on planktonic (Ref. 43081). Rarely captured by prawn trawling vessels. Marketed fresh and frozen (Ref. 9987).
Life cycle and mating behaviorMaturity | Reproduction | Spawning | Eggs | Fecundity | Larvae
Main referenceUpload your references | References | Coordinator | Collaborators
McKay, R.J., 1992. FAO Species Catalogue. Vol. 14. Sillaginid fishes of the world (family Sillaginidae). An annotated and illustrated catalogue of the sillago, smelt or Indo-Pacific whiting species known to date. Rome: FAO. FAO Fish. Synop. 125(14):87p. (Ref. 6205)
IUCN Red List Status (Ref. 125652)
Least Concern (LC) ; Date assessed: 05 March 2015
CITES
Sommer net info vanaf die web. @38cm,n groter dan average een.
